Taurus Fan and Spal controller - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 24th, 07, 10:32 PM Thread Starter
Hi,
I am installing a Taurus fan and have a Spal PWM controller. I see that the fan is a two speed and has 3 wires. Do I just hook the controller up to the high speed wire?
Thanks,
planemech is offline
post #2 of 3 (permalink) Old Aug 24th, 07, 11:06 PM
Re: Taurus Fan and Spal controller
I would try that first, the spal controller w control the fan through 2 wires only.
fotoboy is offline
post #3 of 3 (permalink) Old Aug 25th, 07, 01:18 AM
i would. the controller will give the half-speed so the fan's half speed isn't really needed. btw, don't get it wet. i cleaned the underside of my engine and even with no direct spraying, got condesation inside and it stopped working correctly and never dryed out after a month. i threw it away and got the dummy relay instead. the tech at spal said they already have a new design coming out (because of obvious flaws). maybe you have the new one?
guccieng is offline
