69 headers and compressor bracket - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 29th, 07, 05:25 PM Thread Starter
Dale
I have a 69 camaro, the ac belt keeps coming off. I have headers, and the rear of the compressor is not mounted, only the front of the compressor is mounted.
I have the upper mount for the rear that goes to the intake. Also the bracket on the rear of the compressor that the upper mount bolts to.
The question is, how do you mount the lower part of the compressor?
It has headers. The stock bracket that is mounted to the exhaust manifold will not work.
Is there a bracket I can use to mount the lower rear of an A6 compressor with headers.
Thanks, Dale
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #2 of 4 (permalink) Old Aug 30th, 07, 04:18 AM
Re: 69 headers and compressor bracket
The stock bracket will work if you cut a length of tubing to make up the difference in thickness between the OE manifold and the header flange.
Use heat-treated studs with nuts to secure the bracket instead of bolts.
You might have to go as far as getting a block of steel, or plate steel brackets and make a bracket to fit about the header tubes.
post #3 of 4 (permalink) Old Sep 8th, 07, 03:35 PM Thread Starter
Dale
Well, I ended up usind a piece of 1.5" angle iron and attached it to the 1st and 3rd header bolt holes.
I kept the studs as short as possible, had to cut out some of the steel where the header interfered.
All seems to be working, and doesn't look bad.
Thanks, Dale
dale68z is offline
post #4 of 4 (permalink) Old Sep 8th, 07, 05:13 PM
Cool fix. You might want to paint it with BBQ grill paint. Blast it or sand it to remove rust. I have painted brackets like the one you made with clear coat to leave it steel gray.
