Copper or aluminum Radiator? - Team Camaro Tech
post #1 of 25 (permalink) Old Sep 3rd, 07, 04:31 PM Thread Starter
Do aluminum radiators cool that much better than the oem 23" three row radiator in my 67 AC car ? An OE fit type.
67sprtcp is offline
post #2 of 25 (permalink) Old Sep 3rd, 07, 04:39 PM
Harry
dawg's Avatar
Re: Copper or aluminum Radiator?
yes youll run 10 to 20 degrees cooler
434 stroker
US Navy retired
dawg is offline
post #3 of 25 (permalink) Old Sep 3rd, 07, 04:43 PM
A question that has been debated endlessly.
It's said that copper is really a better conductor of heat. I'm not sure that's true, and I don't know if it holds any water at all once someone puts a couple coats of black paint on one.
Alluminum is cool. It's silver and shiny, and a lotta guys like silver and shiny, myself included. If you're a racer, alluminum radiators are lighter, that at least is fact.
I like my car to run at 180. With a 21" alluminum radiator (2 1" cores) a full "factory style shroud, and a mechanical fan, it will do that, always. Life is good.
If your car will stay at the temperature you'd like it to stay at, your life is good, too.
For comparison, a couple months ago (still in the heat of summer) I needed to pull my alluminum radiator. I put the old original harrison back in, a 21" 2 row. As it was only temporary, I didn't bother putting the shroud on.
She ran at 195 mostly, up to 210 in traffic.
Without the shroud it's noit a great comparison, and your 3 row 23" AC rad has a lot more cooling power than my old one.
post #4 of 25 (permalink) Old Sep 3rd, 07, 06:46 PM
JohnZ's Avatar
Aside from weight, the primary advantage of an aluminum radiator is that the tubes can be wider (more finned surface area exposed to airflow); copper isn't as strong as aluminum, and copper tubes can't be made as wide as aluminum - they'll distort and balloon at that width. With a copper radiator, you're restricted to 3/8" as the maximum practical tube width, and the only way to increase cooling capacity (heat rejection capability) is to add more rows of tubes, which adds weight and each additional row of tubes (like 3 or 4) isn't exposed to primary airflow, so each added row become less efficient than the one in front of it.
With aluminum, the tubes can be up to 1" wide, which exposes a LOT more tube-to-fin surface area to primary airflow; one aluminum tube has the same finned surface area as three rows of copper tubes, and most quality aluminum radiators have two 1" tubes - LOTS more cooling capacity in less space with less weight.
JohnZ
CRG
JohnZ is offline
post #5 of 25 (permalink) Old Sep 4th, 07, 03:34 AM
"Uncle" John is right as usual! I would like to add a few more tidbits to his dissertation.
While copper is a better conductor of heat than aluminum, solder and brass are NOT! The aluminum large tube "footprint" allows for more actual finnal contract as well. Another major improvement is the increase in flow dynamics with larger-tubed designs.
Steve "Jack'stands" Jack
HOTRODSRJ is offline
post #6 of 25 (permalink) Old Sep 4th, 07, 07:29 AM
These guys know what they are talking about 67sprtcp. I learn years ago when I was into off roading, you can't compare an aluminum to brass. The aluminum is that much better.
boonstein is offline
post #7 of 25 (permalink) Old Sep 4th, 07, 07:34 AM
I have run both Copper/Brass & Aluminum. I like both. The debate on this issue will never end. My old 396 BBC had 12.5:1 in it and cammed up well. I ran a monstrosity of a copper/brass 4 row/4 core radiator and it cooled very well even in rush hour traffic all day long. The 350 mouse in my current Camaro likes the Aluminum radiator. Plus the aluminum was an easier install for me as I was doing it by myself. I bought the copper/brass beast and still have it just in case....
But for all those hating on copper & brass check out this link http://www.copper.org/applications/a...s/no_flux.html
***"Aluminum is lighter than copper & brass and it is easier to recycle (recycle = environmentally friendly) which means auto manufacturers are using it more & more today." These aren't my words. This was told to me directly by engineers from Ford, GM & Chrysler in the 1990's & as recently as last year**** I worked for a 5 star Jeep/Eagle/Hummer (Chrysler) dealer in the mid 1990's. I have been out of the auto/tire/service industry since 1998.
Read what one of the best known radiator manufactures had to say about copper & brass vs aluminum http://www.usradiator.com/testing.htm
US Radiator's comments were interesting. I bought my radiator's from D&R Classic. They are a direct fit for my 1969 and from what D&R told me their supplier at the time I purchased my radiator's (about 8 months ago) it was US Radiator. The comments from US Radiator are straight forward & honest.
The SSG&H Bottom Line: I like both. I have used both. As long as the coolant system is pressurized to specifications and items like the t-stat, fan(s), water pump, etc. are working properly you should not have any issues. IMHO, the only advantage with aluminum will be the weight factor and some may say it looks pretty. Well a car doesn't have to look pretty to kick @$$ and function properly.
P.S. Did any of the ZL1's, L88's, or LS6's come equipped with aluminum radiator's? A year ago on this site. I read that in the 1960's some SBC Vette's had aluminum radiators but their BBC fire breathing brother's had big bad super duty copper & brass radiator's. I found that interesting.
1) 1969 Camaro RS 396 TH 400, 12 bolt 3:73 sold 1994
2) 1984 Z28, 5.0 H.O. T-Tops, G92 3:73, sold 1994
3) 1988 5.7L IROC-Z, sold 1994
4) 1969 Camaro bought 2006, back on the road in 2010
Last edited by South Side Goons & Hitmen; Sep 4th, 07 at 08:20 AM. Reason: Chrysler
post #8 of 25 (permalink) Old Sep 4th, 07, 01:38 PM
I hear some say a guaranteed drop of at least 10* ????
"We've learned, for example, that core design has more bearing on temperature drop than material (copper- brass verses aluminum). We've also learned that 2 rows of 1-1/4" aluminum tubes had only a 3-degree advantage over 4-rows of 1/2" brass tubes at 65 m.p.h and a 2-degree disadvantage at idle. Given the added core thickness of the aluminum radiator we had expected a greater temperature drop...but, it wasn't there."
68 Camaro~LSx ~all motor
post #9 of 25 (permalink) Old Sep 4th, 07, 03:10 PM
Well, actually there is no debate per se. Every OEM is now using aluminum radiators in most if not all their applications. The combination of light weight, performance and cost makes it the product of choice. Even these websites offer either bogus or tainted information.. or just plain left out some parts.
I have seen this "spin" on copper here before. All you have to do is look at the very people giving the information. Whilst I will agree that copper out performs aluminum in the heat rejection department,.... the overall features of aluminum gives it the ability to design more efficient crossections (larger tubes and also therefore finnal footprints) and for example, take this quote from their website "Superior thermal conductivity, corrosion resistance and strength.". Okay.. thermal conductivity per gross unit of area..yes, corrosion resistance.. ah...er... ah ever see what copper does when left to the air or water?... NO to that one.....if so why would you have to paint it, and strength.. nope again and I don't care what black magic they spray it with.... aluminum provides a much stronger product and therefore larger tubes can be orchestrated to provide performance enhancements. Then they go on to try and tell you that copper radiators are lighter than aluminum? I don't think so. Go pick one up and see for yourself.
So in essence.. this website is like believing the New York Times? They try to spin the technology into something that befits their products out of context. ... but not automotive radiators per se.
Now.. having said all that.. are there new fangled copper radiators coming along? Probably, but we have yet to see any of them so far... and ANY OF THIS BS on this website certainly does NOT apply to what is available to any of us! So, it is what it is...buy a high efficiency aluminum radiator.
US Radiator makes a great product no doubt. I have done testing in these same areas with aluminum vs copper and gotten dramatically differing results and the reason is that aluminum radiators flow at higher rates by default! With copper/brass systems the "hydraulic resistance" of the system is fairly high both on the suction and pressure sides. TYpical pressure drops with an aluminum radiator is only 1/5psi (at 50gpm rates) with copper ones being three times that! With the larger tubed aluminum radiators the resistance is much lower and the flow rates are appreciably higher. What the study on this referenced page is doing is fixing the flow rate! What? We all know that copper is a better conductor for sure per area..... so fixing the flow rate is NOT an accurate test of the automotive cooling system. Therefore.. the increases in flow will appreciably improve the conduction that they refer to. This is almost by default fraud without flow rates taken into account. To get the perfect comparison they should simply pick an application under controlled conditions and then make measurements. The results would be dramatic I assure you. And.. US Radiator even as good as they are.. does NOT make aluminum radiators and really don't want to tool for that either.. so again ulterior motives creep in.. and it's what you don't know will hurt you. I would throw a top quality aluminum radiator of similar size at any of their copper ones and easily show a 30% improvement.
Okay.. of my soapbox..
post #10 of 25 (permalink) Old Sep 7th, 07, 05:06 AM Thread Starter
Just ordered the direct fit aluminum radiator from jegs. Anyone used one of thier radiators?
67sprtcp is offline
post #11 of 25 (permalink) Old Sep 7th, 07, 09:31 AM
I did the same but from summit ($289 up to 400HP)
? Any good I hope so . Griffen & be cool $500 and up.
1968 Camaro RS
skar is offline
post #12 of 25 (permalink) Old Sep 7th, 07, 10:35 AM
DjD
DjD's Avatar
Just some common sense thrown in here... We debate alum vs copper/brass ad-nausea. The bottom line is they both work and can work with higher horse power applications. Talk to your local radiator shop and they will tell you alum can't be fixed if damaged, and can't be rodded out like a brass/copper unit can. Brass/copper also isn't prone to electrolysis like alum is. The modern oem alum radiators I see on new cars are alum cores with plastic tanks that are crimped and glued together. Should the hotrod world follow the oem lead here as well? They work well in new cars don't they!
My whole point is and I tried to make it in the last thread asking "what's the best?" it's all about what you want and what you are trying to achieve. You can re-core a stock set of tanks with staggered tubes or buy a stock style replacement if you want to retain some of that vintage look even if you are leaning towards pro-touring. You can run a big polished alum radiator and vintage finned or MT valve covers too if that is what you want. The best is relative at best, Someone driving a 550 Maranello might laugh at a chevy with respect to "best" just as some chevy guys are arguing over best radiator. Both a Chevy and a Ferrari will get you down the street. Do you need the Ferrari though? Same with Alum vs Brass/copper radiators... Alum is one answer to cooling your classic, it's not the answer though. Same with electric fans... I'm not against Alum radiators or electric fans, I just know the other stuff works and works well if it's setup properly and maintained well.
...Dennis
DjD is offline
post #13 of 25 (permalink) Old Sep 7th, 07, 10:59 AM
you should add to that statement "if your current radiator isn't up to the task". My current copper/brass rad runs at 180 with a 180 thermostat, so it's doing its job. An aluminum radiator should still run at 180 with a 180 thermostat.
BPOS is offline
post #14 of 25 (permalink) Old Sep 9th, 07, 09:30 AM
Dennis.. while I know you try to appease everyone here with their points of view and experiences and I respect that and I agree with most, but on this subject I couldn't disagree with you more with all due respect as to "what is best?". Maybe I/we are saying the same thing just in different perview/context... I don't know?
Unfortunately, some more ad nauseam..... when someone asks what's BEST or in this case "does aluminum work"?... it's black and white for the most part to me (yes.. I am an engineer and things appear to me this way to a probably fault) . Yes.. I do agree tht money has something to do with it and I really respect those who are on a tight budget for sure (been there... and well.... still there).... but when you want the BEST.. .there is A BEST! And moreover it's all to do with design and media frankly. While application(s) dictate fitment.. the rest is pure physics.
Don't get me wrong...there is NOTHING WRONG with brass/copper/radiators per se, if they are adequate for your applications then GREAT don't go change for the sake of change! But, the more hp you add and the want and need for more conditions in which to be able to function (such as here in Atlanta traffic) with air conditioning wanted as well... the old OEM stock radiators (and other parts for that matter)are NOT the "best", period. I hate to burst everyones bubble on this! Even in their day it was nip and tuck... I had a 65 SS Impala with air that was marginal at best in Indy climates and NO traffic to speak of. I had a number of friends that had everything from BB Corvettes to 440 GTXs and all had marginal cooling systems in high temperature environments. One of my friends fathers had the largest Chevrolet dealer in the midwest and they were commonly plagued with "performance car cooling issues" to quote his father directly. This was due to OEM designs and specifications in their day.
And, let's face it.. we are making more hp with those very same engines with improved VE numbers .. even some of the pure stock applications will make better than "factory" claimed horsepower numbers easily with the availability of low restriction exhaust/headers, induction systems and just boring out those engines for rebuilding changes everything. And.. add airconditioning.. well that's another hit needing more efficiency. Also, in traffic ladened communities (and traffic has increased expotentially as we all know in every place) the tarmac/road ambient temperatures has increased dramatically too. When sitting at a light in Atlanta 30 years ago the ambient pavement temperature might have been 5 to 7 degrees higher than the ambient. Today.. it's typically 12 to 20 degrees!! Hence, you have to have a more efficient cooling system to get you the same performance as you did in yesteryear at the same intersection usually. I get literally dozens of emails or phone calls a month from either car builders and/or owners asking why their 502 is not cooling when they put it in their "stock" application cooling system. I have seen this hundreds of times!
Today's applications are much more sophisticated for sure...OEMs today design for much higher demands than 30 years ago do to these wanted conditions. Now, OEMs are designing for maximum tarmac/road surface input temps (air that actually gets sucked into the radiator for cooling) in excess of 125 degrees, whereas in 1967 is was only 100 degrees. This is NOT my opinion, but actual GM specs now.... as well as other OEs. While you can poke fun at OE radiators with plastic tanks.. actually some of these will cool better and last longer than conventional all metal radiators. Yeah.. yeah.. I know... they are supposedly cheaper but composites used for these are sometimes tougher than our traditional thinking "metal" in radiators for sure and will take more flexing and abuse and are actually engineered for that specific application. But I agree with most here... I myself would not pick one of these for my applications either... I want ALL aluminum!
"Why aluminum?" is the question and just what makes it "the best" choice? Again.. no big deal if you have a copper/brass one..... and their are plenty of quality vendors out there for sure.... so if it works.. don't change it! While aluminum is lighter and yes.. somewhat less in the thermal conduction department (when compared to copper), it is also stronger and this is the very key to it's success for cooling efficiency. This "stronger" element of aluminum allows the functional tubes to be designed in ways that are far more efficient than just the "conduction" transfer losses compared with copper/brass. Aluminum tubes can be made not only larger, but manipulated for custom size, footprint and internal coolant control that you can't get with copper. And.. on the external design front, large aluminum tubes will have appreciably more finnal "footprint" than smaller copper tubes and will not need four or five rows of tubes (which each row gets less efficient as you progress back thru the radiator core). This is another huge design upgrade(s) with increase in heat reject ability. Another major issue that affects the overall cooling ability of either radiator is flow. Larger tubes present far less "flow resistance" both on the pressure and suction sides. Because our water pumps are centrifugal designed and not "positive displacement" designs, resistance to flow is a real upgrade if you can reduce this. The result is that you will see a flow increase thru the aluminum designs.
Simply put, area for area with the same waterpump source provided, the large-tubed aluminum radiators will provide in the area of 25% to 40% more heat rejection due to all these aforementioned features when compared to a copper/brass/solder model. This is why all the OEMs are using aluminum now. Smaller footprints, higher flow, high efficiency designs all contribute to a "best" product.
So, what is best for improving "overall" cooling in general? Notwithstanding the radiator upgrade, there are simple and inexpensive upgrades to the stock system (or any system for that matter) that can help. First, flow is king and any quality aftermarket high/volume water pump will increase flow dramatically throughout the RPM range. Old OEM stock waterpumps flow about 5 to 7 gpm at best at idle and only 35 to 40 gpm at cruising rpms. Typical high volume aftermarket waterpumps will produce from 12 to 18 gpm at idle and 50 to 65 gpm at cruising rpms (some even as high as 80gpm!). As you can see a huge improvement. Any airflow improvement will also be an efficiency improvement. While stock fans are okay for stock applications, it's oft found out that they are NOT adequate for higher hp or demand applications. Upgrading your fan to a larger/more blades etc one may work, but high output electric ones will out perform any stock mechanical fan period. A classic example is the Mark VIII fan with around 4000 cfms of production. There is NO OE fan that will come close, albeit you will have to make electrical upgrades for the Mark VIII as well.
And.. finally just to clarify some other points please..... "aluminum radiators are susceptible to electrolysis". While this used to be an issue with only a handfull (and small surface areas) of aluminum parts present in the system, with an aluminum radiator (and high surface area availability) and quality corrosion (or antifreeze) inhibitors this is not a problem at all. Mixed and matched metals in modern OEM applications survive without problems as long as you maintain the cooling system. This is also easily checked on as well. Another point... aluminum radiators can't be "rodded" out etc. Well, actually if you maintain your cooling system with modern long-lived antifreezes and corrosion inhibitors and use distilled water, you will have NO NEED for rodding out period. Also to your point... you can't repair aluminum (sometimes is true), but aluminum is much stronger (especially the welds and tube thickness/strength) and the incidence of repair (this according to seven OEM acuarial information on failures) or failure is only 17% of copper/brass models of yesteryears. So, the reliability factor with fully aluminum radiators is huge simply due to their inherent strength! This is another motive for the OEs to to toward aluminum.
Now..... for everyone out there that does not know me.. I will restate for the record that I do NOT have anything to do with any of the vendors here...or anywhere else for that matter. I think I am a pretty "balanced and fair" reporter really.. with just the science to back me up. So to me.. it's black and white. Any design which offers any of these improvements and features will be the "best".
Pardon the Interuption!
post #15 of 25 (permalink) Old Sep 9th, 07, 10:04 AM
DjD
DjD's Avatar
Sorry Steve, I just couldn't get through all that... You lost my interest when you said "if they are adequate for your applications". The word adequate implies just barely sufficient or satisfactory... I'm sure you will want the last word so have at it and I won't reply and perpetuate this further!
...Dennis
DjD is offline
