radiator as a fuel cooler? - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 5th, 07, 06:18 AM Thread Starter
I just did a auto to manual swap and my old automatic cooler lines to the radiator are no longer needed. Is there any reason I cant use the radiator as a fuel cooler now that the automatic cooler lines are gone?
wheezer is offline
post #2 of 7 (permalink) Old Sep 5th, 07, 08:16 AM
Re: radiator as a fuel cooler?
how hot is your fuel? i think that would be a fuel warmer more than anything. i don't know of a car that has fuel hotter than 190-210 degrees. i'd bet money the fuel in your tank is cooler than that, and should be enough to keep the lines cool, especially with a return line. jegs sells a cool can that can be filled with ice to cool fuel down if needed, otherwise i'd recommend covering the lines with a heat shield. i'd never put it through the radiator!
guccieng is offline
post #3 of 7 (permalink) Old Sep 5th, 07, 11:02 AM
Ditto what John said! The transmission fluid "cooler" built into the rad is a relative thing; it's designed to dissipate heat in the fluid to make the trans fluid cooler than the trans operating temp. It is not a chiller...
Eric
Eric Kammerer is offline
post #4 of 7 (permalink) Old Sep 5th, 07, 02:34 PM
180* + fuel temp ... Can we say vapor lock.
68 Camaro~LSx ~all motor
post #5 of 7 (permalink) Old Sep 5th, 07, 05:44 PM
george
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #6 of 7 (permalink) Old Sep 6th, 07, 01:54 PM
Also think about this...
As you heat a flamable liquid it becomes easier to ignight . Look up "flashpoint".
post #7 of 7 (permalink) Old Sep 7th, 07, 02:49 PM
Ambient temp Vs. Engine temp. Not rocket science.
TC # 349
zdld17 is offline
