Replace Water Pump 1967 327 2bbl RS w/AC - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 7th, 07, 04:51 PM Thread Starter
frank
Frankrentef's Avatar
Been running "my girl" on short jaunts, replaced the thermostat fan and now find that the water pump appears to be leaking around the shaft (as best as I can tell.) Picking up the replacement tomorrow along with a new thermostat. Looking for advice / experience on doing the job. Do I need a torque wrench when putting it back together? I've heard of a few guys talk about over tightening valve cover gaskets to the point of cracking them. Can this happen on a water pump gasket? How tight should I go?
This car has been sitting for a lo-ong time and I think a few things are starting to shake loose. My plans are to pull the engine come late fall. I'm just after running it some to see what shape she's really in (and to enjoy my long anticipated toy.)
THNX to all on this site for past help!
Frankrentef is offline
post #2 of 9 (permalink) Old Sep 7th, 07, 04:57 PM
Harley
wiskeesour's Avatar
Re: Replace Water Pump 1967 327 2bbl RS w/AC
I havent used a TRQ wrench for the water pump and gotten away with it. Just get them good and snug and do this in a cross pattern. Its 4 bolts; top-left, bottom-right, etc, etc. Good gaskets and youll be fine. Clean the surface of the block with some cleaner or a putty knife.
Valve cover bolts break from being so small and the thought of the valve covers having to be so tight. I use studs in the heads for the valve covers....all-thread bought from Home-Depot and they work great.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 9 (permalink) Old Sep 7th, 07, 06:58 PM
Tory
Camaros-n-Chevelles's Avatar
Also, Change your Upper and Lower Hoses and Flush the system while you are doing the job. Might as well change your Heater hoses too.
Tory
Camaros-n-Chevelles is offline
post #4 of 9 (permalink) Old Sep 8th, 07, 05:18 PM
JohnZ's Avatar
Use thread sealer on the water pump bolts - they go through into the block water jacket.
JohnZ
CRG
JohnZ is offline
post #5 of 9 (permalink) Old Sep 8th, 07, 07:24 PM
Make sure the bypass hole is open and free.( thats the extra hole on pass side block that does not have threads)
TC # 349
zdld17 is offline
post #6 of 9 (permalink) Old Sep 9th, 07, 06:39 AM Thread Starter
frank
THNX to all! Have the old one out, now to get the new one in.
post #7 of 9 (permalink) Old Sep 9th, 07, 07:22 AM
Charlie
Please be careful. I know it may be hard to believe, but if a bolt is fatigued it can break. I had one of my water pump bolts break and I didn't even get to snug it. I guess from being removed and installed multiple times it wore it out. I was luck that enough of the bolt was sticking out of the block that I could remove the pump and get a monkey wrench on it. Not a normal thing to have a bolt like that break, but it does happen.
67CamaroRS/SS is offline
post #8 of 9 (permalink) Old Sep 9th, 07, 08:08 AM Thread Starter
frank
Good advice,
I'll pick up new bolts before I reinstall. Spend a few pennies now, save much headache later.
67 Camaro RS - 383 Stroker
Factory A/C - Muncie 4 speed
post #9 of 9 (permalink) Old Sep 9th, 07, 01:04 PM
Charlie
I am usually not the lucky one, but when it broke it left just enough to get a pipe wrench on it. What a relief.
