Jeg's radiator - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 11th, 07, 02:56 PM Thread Starter
Jeg's radiator
Has anyone used Jeg's direct fit radiator (part #555-51900)? If so how was the fit and can I use the factory shroud? I'm also looking at getting the Black Magic X-treme fan (part #400-180). I can get the items shipped to the house a little cheaper than from Summit. Thanks
slammys69 is offline
post #2 of 8 (permalink) Old Sep 11th, 07, 05:50 PM
Tony
Re: Jeg's radiator
Anybody use the JEGs version? I am looking at the same thing and for the same reason's.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #3 of 8 (permalink) Old Sep 11th, 07, 06:34 PM
Charlie
Re: Jeg's radiator
I have the Flex-A-Lite Black Magic fan #180 and I think it's a very nice fan. IMO, it's well built and it attaches nicely. The only thing I don't like is the mounting brackets have a slot in them instead of individual holes for the mounting bolts. I will probably make some "L" brackets out of some stainless steel I have and drill a hole in it in the same place as the bracket. Other than that it is a very nice unit. They give you an adjustable thermostat, but it's the type with the bulb on a long wire instead of a screw in switch. I already had a Painless fan switch in my manifold so I didn't use the thermostat.
67CamaroRS/SS is offline
post #4 of 8 (permalink) Old Sep 11th, 07, 06:54 PM
Re: Jeg's radiator
I just got that radiator today from jegs and if you have a pretty nice car I would noy go with it. The welds on the tanks look awful. Try the summit direct fit. I heard they are good. Looks like the jegs was built by a first time welder or a drunk. I am returning mine.
67sprtcp is offline
post #5 of 8 (permalink) Old Sep 12th, 07, 09:29 AM
Codi's Avatar
Re: Jeg's radiator
Let Jegs know about the welds. THey seem to take these responses into consideration, at least they took care of my last complaint. I even got a phone call from a high up honcho about my complaint and the "item" was replaced with another brand.
Daddy's Hot Rod.
Codi is offline
post #6 of 8 (permalink) Old Sep 12th, 07, 10:03 PM Thread Starter
Re: Jeg's radiator
Looks like I will be going to Summit.
post #7 of 8 (permalink) Old Sep 13th, 07, 03:06 PM
Tony
Re: Jeg's radiator
Drove down to Summit today and picked thiers up. Looks pretty good to me (not TIG welded ala Nascar style but the price is right). All mounting hole line up and it is a pinch thicker. Got out of there for less $$$ than the Jegs version when I mentioned the competition to Summit.
Tony:
idoxlr8 is offline
post #8 of 8 (permalink) Old Sep 13th, 07, 07:03 PM
Re: Jeg's radiator
Maybe I got a bad one from jegs, but I will go with summit.They look alot alike.
67sprtcp is offline
