Anyone use Aeroquip EZ clip system? - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 18th, 10, 09:33 AM Thread Starter
Ted
Has anyone used the EZ clip system for both A/C and heater hoses? Do you like them?
tgifford5 is offline
post #2 of 3 (permalink) Old Mar 18th, 10, 09:42 AM
Re: Anyone use Aeroquip EZ clip system?
I used them for my in-process build for the AC, but not the heater. I can only say that they are easy to work with and appear to provide a good leak proof connection.
Mike - '68 Camaro - aftermarket or modern pretty much everything.
Mkelcy is offline
post #3 of 3 (permalink) Old Mar 18th, 10, 10:05 AM
Never used the EZ clip stuff but I have used their nickel plated steel A/C fittings and Stainless A/C hose to make the A/C lines for the Vintage Air setup in the Camaro. I had one issue with a fitting but it was my fault. I didn't get the hose flush into the brass compression fitting and it leaked. I took it apart, threw out the old compression fitting, cut a 1/8 inch off the hose and tried a second time. Got it right that time no leaks in over a year. Using the stainless braided hose is a pain but when you get it right it sure looks good.
There's a fine line between hobby and obsession and I think I crossed it!
69 Camaro SS 350 4 Speed (5 Speed)
69 Corvette L46 Roadster 4 Speed
99 Corvette 1SC Roadster 6 Speed
Hot Rod Power Tour Long Hauler 08, 09, 10, 11, 12 & 13
69SS 350 5 Speed is offline
