Heater core box on the fire wall side ? - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 21st, 10, 09:28 AM Thread Starter
Clint
Talking Heater core box on the fire wall side ?
I have searched for this Question but know luck.. Would it be safe to say that the Quarter panel would have to come off in order to get the housing off the fire wall ? there appears to be 1 or 2 more nuts or bolts that you just cant get to . this is on a 67 camaro .
mccann is offline
post #2 of 9 (permalink) Old Mar 21st, 10, 09:36 AM
Re: Heater core box on the fire wall side ?
Yes take the front fender off.
john68 is offline
post #3 of 9 (permalink) Old Mar 21st, 10, 09:46 AM Thread Starter
Clint
Thanks i kind of figured almost hated to ask the ?
mccann is offline
post #4 of 9 (permalink) Old Mar 21st, 10, 03:51 PM
If you're changing the heater core, the engine side does not have to come off.
Remove the six nuts shown on the engine side, remove glovebox, and pry off the box inside after removing coolant. Lay down one piece of plastic to cover from the trans tunnel to top of toeboard to seat to over the rocker panel to collect remaining coolant from core.
Cables don't have be disconnected either. Use 5/16 inch socket to remove clip and pull out core. Compare size of replacement to OE core if still there. Some here have said new cores are of thinner design. If you can, have OE core repaired and replace in reverse order.
You can use clay weatherstripping to reseal the core box back against the firewall.
Instructions are for a non-A/C heater - I haven't done one of them.
post #5 of 9 (permalink) Old Mar 21st, 10, 04:13 PM
Keep searching "heater core". There are volumes on this topic.
Melrose RS is offline
post #6 of 9 (permalink) Old Mar 21st, 10, 08:07 PM Thread Starter
Clint
Thanks guys all info helps but i am changing to a big block core and new fire wall housing for the blower is required. Or it sounds like i could of just modified the old one.Fender is off now not quite sure which one would of been easier ?
mccann is offline
post #7 of 9 (permalink) Old Mar 22nd, 10, 02:23 AM
A search will uncover the conversion process and which cores fit what. Origional BB heater boxes were indeed different dimensonallly but the conversions do not require an origional BB box. Pressure test the heater core prior to installation, others have found some to leak after all the work.
Sauron67MM is offline
post #8 of 9 (permalink) Old Mar 22nd, 10, 05:12 PM Thread Starter
Clint
thanks for the response i am assuming your talking aboutpressure testing the newley purchased heater core . I just took te old one out and it was green on the bottom of it due from leaking . thank god i pulled it out before replacing all the interior .
mccann is offline
post #9 of 9 (permalink) Old Mar 27th, 10, 06:24 PM
Vall
Changing because you're changing to a BBC engine? If so, you can flip the core to make the outlets move to the center, then drill holes for the outlets and block the old holes. I have a smallblock heater box and core in the normal position with my BBC 427, and never had any clearance issues with it.
Not sure why everyone is changing them, unless they just want that OEM look.
1971BB427 is offline
