Clutch fan? - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 27th, 10, 11:52 PM Thread Starter
mike
Clutch fan?
looking to get a clutch fan "standard duty" or "heavy duty" ?
$Mike70Z-28 is offline
post #2 of 8 (permalink) Old Mar 28th, 10, 10:58 AM
Steiner
Re: Clutch fan?
Heavy duty gives you more more air flow. You must use a heavy duty fan if using a heavy duty clutch. A heavy duty clutch lets the fan spin faster.
Standard duty clutch spins fan at around 60-70% of engine speed and most standard duty fans are rated for 4000 RPM, or around 6500 RPM engine speed max.
Heavy duty clutch spins fan 80-90% of engine speed. A heavy duty clutch with a standard duty fan is a recipe for disaster.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 8 (permalink) Old Mar 28th, 10, 11:09 AM
DT
Donny
DT's Avatar
Re: Clutch fan?
Use a Flex fan from Flex -O-Light
DT is offline
post #4 of 8 (permalink) Old Mar 28th, 10, 11:55 AM
Steps
Re: Clutch fan?
Srick with the clutch...match to your fan and engine as suggested above.
Run a forum search on the the subject, the factory clutches/fans are very effient and trouble free.
Steptoe is offline
post #5 of 8 (permalink) Old Mar 28th, 10, 01:09 PM Thread Starter
mike
Re: Clutch fan?
im looking to put 7 blade 18"
post #6 of 8 (permalink) Old Mar 28th, 10, 04:29 PM
Re: Clutch fan?
yeah, who needs to have the best cooling setup as designed by the factory engineers when you can have a flimsy thing that flattens out at high rpm and impedes airflow thru the radiator core..
you don't plan sincerity.
novaderrik is offline
post #7 of 8 (permalink) Old Mar 28th, 10, 09:17 PM
Steps
Re: Clutch fan?
Flex fans will not pass many track scruteenering over here
and above post...
They are Bs .
Mike there is no need to go overboard on the fan...
the stock radiator is way over built if all the cores are clear
The fan is only needed at low very rpms/speeds
And the std fan moves way more air than is needed.
Steptoe is offline
post #8 of 8 (permalink) Old Mar 28th, 10, 10:43 PM Thread Starter
mike
Re: Clutch fan?
the fan i have is stock (3947772) 7blade 18" i just wanted to know for the clucth "standard duty" or "heavy duty" ?
