Heater core bypass valve. - Team Camaro Tech
post #1 of 14 (permalink) Old Apr 5th, 10, 09:25 AM Thread Starter
Heater core bypass valve. I would like to bypass the heater core in the summer on my 68 camaro. Would like to find a H valve that I could put in the heater hose to bypass in the summer and turn valve for heat on cold spring and fall days. I was told old Ford F150 had such a thing?
I would like some thing that looks good . No vacuum or cable I can turn the valve by hand when i need it.
1968 Camaro RS
skar is offline
post #2 of 14 (permalink) Old Apr 5th, 10, 09:36 AM Thread Starter
Re: heater core bypass valve.
? Would something like this work.
http://cgi.ebay.com/ebaymotors/15-55...item3efd245c23
or
http://cgi.ebay.com/ebaymotors/ws/eB...49282284890730
1968 Camaro RS
skar is offline
post #3 of 14 (permalink) Old Apr 5th, 10, 05:04 PM
Russ
Electronic version of a bypass
a little pricey though at $94.
Blown 69 RS Camaro
383 Small Block
Dyno: 578 Horse - 595 LB/Torque
Blown69RS is offline
post #4 of 14 (permalink) Old Apr 5th, 10, 05:40 PM Thread Starter
Thanks but I would like to keep it simple and stick with a manual switch . (by hand and finger) I take it the other two will work
1968 Camaro RS
skar is offline
post #5 of 14 (permalink) Old Apr 6th, 10, 12:35 AM
You don't need an H shaped one. You can just put an open/closed valve in one line. Coolant does not need to flow through the heater hoses.
Just close the valve hot coolant will not flow though the heater core and your good.
400bird is offline
post #6 of 14 (permalink) Old Apr 6th, 10, 02:58 AM Thread Starter
Ok makes sense . Like a T then . ? who sells them. I will look.
1968 Camaro RS
skar is offline
post #7 of 14 (permalink) Old Apr 6th, 10, 07:28 AM
click's Avatar
I used a brass valve from plumbing supply store that is for PEX type tubing. Its ribbed and slips right into the hoses.
click is offline
post #8 of 14 (permalink) Old Apr 6th, 10, 09:43 AM Thread Starter
All good but I saw this on a vette form.
http://www.harborfreight.com/cpi/cta...emnumber=65116
May go this way????
1968 Camaro RS
skar is offline
post #9 of 14 (permalink) Old Apr 6th, 10, 11:09 AM
Robert
May go this way????
I dont think I'd use those for a long term fix. You may wind up with a leaky hose. I use a valve similar to Click.
Robert
TC member #18
rojo is offline
post #10 of 14 (permalink) Old Apr 6th, 10, 12:27 PM Thread Starter
OK I went with this.
http://www.amazon.com/dp/B000C2Q8D4/...SIN=B000C2Q8D4
NOW which hose to splice it in. From intake or water pump?
1968 Camaro RS
skar is offline
post #11 of 14 (permalink) Old Apr 6th, 10, 12:30 PM
Intake, Hot side.
john68 is offline
post #12 of 14 (permalink) Old Apr 6th, 10, 12:51 PM Thread Starter
thanks.
1968 Camaro RS
skar is offline
post #13 of 14 (permalink) Old Apr 16th, 10, 07:35 PM
BARTELL
Re: Heater core bypass valve.
My research brought up the fact that if fluid is shut off on one side, the excess that is left in the core will cause clogging. Anyone heard of this?
BTELL67 is offline
post #14 of 14 (permalink) Old May 5th, 10, 06:50 AM
Michael
I use the 1972 Camaro AC/heater valve in my '67.
My heater core has never clogged from using the valve.
mahunt is offline
