Cooling an AC equipped 69 BBC...possible? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 11th, 10, 04:40 PM Thread Starter
Louie
rad454's Avatar
I started her up this weekend and it only took 2 cranks before she roared to life. I was watching the guages and all looked fine but I noticed that the temp needle was hovering in the middle of the guage (center console)
It is only about 65 degrees here and I can only imagine what it would have done in summer where it hits 95 pretty routinely. When I install the vintage air system the radiator will have that to deal with that as well.
Here's what I have:
468 BB with 16 degrees initial timing set by the engine builder (knows his stuff)
650 street Demon
Roller cam (street use)
New 4 core copper radiator
160 degree thermostat with the holes drilled to let air out when filling
High volume, pulley driven H20 pump
stock 6 blade fan with shroud in place (fan is about 1/4 of an inch from the radiator and 1/2 way into the shroud, it looks good.
Whats the simple/cheap way to cool an AC equipped BB? Can I put a pusher fan in front of the 2 radiator's or is it simpler to buy a whole new system? I may have to hock the wifes jewelry to do the latter.
69 SS/RS Fathom Green 454 4 speed
Bumper sticker- My other auto is a .45
rad454 is offline
post #2 of 5 (permalink) Old Apr 11th, 10, 04:42 PM
Skip
Skeeter55's Avatar
Re: Cooling an AC equipped 69 BBC...possible?
No air pockets in the cooling system. Still should run a 180* stat minimum.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 5 (permalink) Old Apr 11th, 10, 05:39 PM
george
I would not change a thing right now.Lets see how much the increase in ambient temp affects coolant temp with the ac compressor engaged.
You may be sweating a moot point..pun intended.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #4 of 5 (permalink) Old May 7th, 10, 12:52 PM
Michael
Just leave the fenders off (like in the picture) and the car should never get hot.
You "may" want to consider an aluminum radiator for A/C usage.
mahunt is offline
post #5 of 5 (permalink) Old May 7th, 10, 01:06 PM Thread Starter
Louie
rad454's Avatar
I noticed that the temp gauge pointer , when engine is cold, drops to the 1/4 mark and stays there. I'm going to take a seperate gauge and test it, but it wouldnt suprise me if the actual temp is much lower than indicated.
rad454 is offline
