Low vacuum to Plenum valves - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 17th, 10, 02:51 PM Thread Starter
Here is my problem. The two vacuum activated doors for air flow on my 68 with factory air are not opening. I'm getting a reading of about 5 on a vacuum gage connected to the lead for the kicker plenum valve. From the engine I have about 18 so I'm leaking somewhere. Is there a common place to look first? Everything is such a pain to get to I'm hoping someone may suggest the most likely place to start.
sthoma10 is offline
post #2 of 4 (permalink) Old Apr 17th, 10, 02:56 PM
Re: low vacuum to Plenum valves
the hoses are the easiest, the switches, next, vacuum can under drivers front fender
is bad. Just for the hoses is a pain, to the can.
john68 is offline
post #3 of 4 (permalink) Old Apr 17th, 10, 02:57 PM
Sorry I should have started "do you have the service manual" ??
john68 is offline
post #4 of 4 (permalink) Old Apr 17th, 10, 03:39 PM Thread Starter
Yes I do. Thanks
sthoma10 is offline
