2 temp sending units - Team Camaro Tech
post #1 of 20 (permalink) Old Apr 23rd, 10, 08:06 AM Thread Starter
Team, I placed a temp sending unit for my temp gauge in my Edelbrock Manifold. I am now installing my radiator and want to control fans with a 185 sending unit switch. No place in the manifold for a second sending unit. Any ideas on how to do this??? Thanks…
Clean 67 - 600hp / 579ft lb, 502
St Petersburg, FL
mccomas is offline
post #2 of 20 (permalink) Old Apr 23rd, 10, 09:05 AM
Ted
Re: 2 temp sending units
What manifold do you have? I just glanced at the Eddie website and it looks as if there are 2 positions for the temp sending units. One on the drivers side and one on the passenger side.
tgifford5 is offline
post #3 of 20 (permalink) Old Apr 23rd, 10, 09:13 AM
The cylinder heads should have pipe plugs you could remove to install a sending unit. You can also purchase a thermostat housing with provision for a sending unit.
BPOS is offline
post #4 of 20 (permalink) Old Apr 23rd, 10, 10:07 AM
prostreet69camaro's Avatar
Just remember the head will have a hotter temperature. Usually about 10 to 15 degrees difference between the intake manifold and head.
I tried using the preset sending unit but ended up buying the digitial dokata adjustable thermostat control.
prostreet69camaro is offline
post #5 of 20 (permalink) Old Apr 23rd, 10, 10:42 AM Thread Starter
After thinking a bit more on this - the fans should come on based on water temperature coming out of the radiator. What do you thing about something like this mounted in-line with my lower radiator hose???
St Petersburg, FL
mccomas is offline
post #6 of 20 (permalink) Old Apr 23rd, 10, 07:16 PM
seems like too much work to me ...just use one of the 2 head plugs. If you aren't seeing those look between middle two header tubes on each side. Probably not too important but the heads handle a lot of the engine heat so a good place to see the coolant heat by the sensor.
68 coupe ,572,tko
Denvervet is offline
post #7 of 20 (permalink) Old Apr 23rd, 10, 07:40 PM
Steiner
Those 185 switches come on at 185 and off at 170. I'd be inclined to think that if you put it in the engine the fan would never turn off.
Typically you want your probe in the radiator. If there's no port in it or you can't replace the drain with a sensor, there are controllers that mount to the fins.
Here's the $27 adjustable one from Flex-a-Lite:
http://www.flex-a-lite.com/auto/31147-99936.pdf
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 20 (permalink) Old Apr 24th, 10, 02:12 PM Thread Starter
Placing the sender in the drain **** sounds like an excellent idea... Think this is the way I will go…
St Petersburg, FL
mccomas is offline
post #9 of 20 (permalink) Old Apr 26th, 10, 03:51 AM
You can also get thermostat housings that have threaded ports for temperature sensing devices.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #10 of 20 (permalink) Old May 6th, 10, 01:20 PM Thread Starter
After some thought, I decided not to place temp sender in drain petcock. The water has been cooled by the time it gets to the bottom of the radiator so I went back to inserting the sender in the top hose. I really think this is the best place to control fans via water temperature. The insert was about 25 bucks and it has a clean look… it is “taped on” in the pic…
St Petersburg, FL
mccomas is offline
post #11 of 20 (permalink) Old May 28th, 10, 05:47 AM
ZZ_430's Avatar
never mind
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #12 of 20 (permalink) Old May 28th, 10, 06:01 AM
Steiner
You've got a nick on your fender brace you slob.
'69 Camaro
500hp/538lbft
Steiner is offline
post #13 of 20 (permalink) Old May 28th, 10, 07:45 AM
Guess
HwyStarJoe's Avatar
I haven't installed it yet, but I have an adjustable fan controller that has me putting the probe into the upper hose. That means running the little probe wire deal between the hose and the radiator fitting.
Seems like an easy place to spring a leak! I didn't know it mounted like that when I picked it up. Should I seal the probe wire to the fitting with some high-temp RTV before I slide the hose back over it?
HwyStarJoe is offline
post #14 of 20 (permalink) Old May 28th, 10, 11:07 AM Thread Starter
Joe, no need to goop it up with anything. I ran one like that on a truck. The rubber hose will bite done on it and seal just fine... At least mine did. ran it for years...
St Petersburg, FL
mccomas is offline
post #15 of 20 (permalink) Old May 28th, 10, 01:27 PM
Steps
I despute this..
If on uses a gun to check the area yes..
I have 2 sencors 1 for the gauge the other for the idiot light...one is resistance the other a switch set at 230 drg.
I played around with swaping them over yrs ago when had issues of the gauge not reading right....the difference is only 3 to 5 degs...but the head does give hotter readings faster until the thermostat opens
Steptoe is offline
