400 small block cooling question - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 25th, 10, 05:04 PM Thread Starter
I have a friend that has a 400 small block and the car he has it in has had the heater box completely removed. My question is can he use a pipe plug and plug the heater hose fitting on the intake manifold and also use a pipe plug and plug the fitting on the top of the water pump or do you have to run a hose from the intake fitting to the water pump fitting? If he plugs both off will there be any heating issues that would be caused by plugging the fittings off? I think he can plug them off and be fine but I am not sure. Any replys would be great. Thanks
dshook is offline
post #2 of 2 (permalink) Old Apr 25th, 10, 05:16 PM
Re: 400 small block cooling question
Plug the holes... non-issue..won't hurt a thing. Been like that since I owned the car and swapped the motor in the first 3 months.
68 Camaro~LSx ~all motor
