cooling 350 - Team Camaro Tech
post #1 of 8 (permalink) Old May 2nd, 10, 04:21 PM Thread Starter
corey
cooling 350
hey I was just wondering I have a 1982 cutlass with a chevy 350 comp cam 270 performer intake holly 670 carb , I have a 4 core aluminum rad with the stock clutch fan and a secendary electric puller fan, I have a 180 thermastate , but on Idle the car runs about 195-200 and dosnt really come down is this ok ?
steps350 is offline
post #2 of 8 (permalink) Old May 2nd, 10, 06:22 PM Thread Starter
corey
Re: cooling 350
anyone have any info?
steps350 is offline
post #3 of 8 (permalink) Old May 2nd, 10, 06:27 PM
Ted
Re: cooling 350
That temp is fine. But your secondary fan should be a pusher. Your stock clutch fan is the puller. If you have a secondary fan in front of the radiator it should be pushing air through. Otherwise the two fans are working against each other. Was it running hot before adding the secondary fan?
tgifford5 is offline
post #4 of 8 (permalink) Old May 2nd, 10, 09:32 PM Thread Starter
corey
Re: cooling 350
ya I just put it on to be a pusher tonight and it is still running around the same temp it was just worrying me
steps350 is offline
post #5 of 8 (permalink) Old May 3rd, 10, 07:59 AM
Ted
Re: cooling 350
Do a search in this section of the forums on cooling temperatures. You're right in the ballpark. Those temps are needed to burn off the contaminates. What was your temps before adding the pusher? Are you using a fan shroud?
post #6 of 8 (permalink) Old May 3rd, 10, 11:50 AM Thread Starter
corey
Re: cooling 350
the temps were about the same and my bottom shroud is off is that ok or no?
steps350 is offline
post #7 of 8 (permalink) Old May 3rd, 10, 12:39 PM
Steps
Re: cooling 350
NO.
Without the shroud the fan efficiency drops dramatically...the air spills of the ends of the blades
look at an electric fan or even a computer case fan....they can move a lot of air for the size of the fan...because they have shrouds.
Very often causes of runing warm are not just 1 issue
1982 cutlass
OK has that radiator been flushed and cleaned regularly from new ...I duobt it
How many bottom hoses has it gone thru, a couple...thats a lot of corroed and broken reenforcing springs blocking lower cores.
Steptoe is offline
post #8 of 8 (permalink) Old May 3rd, 10, 11:26 PM Thread Starter
corey
Re: cooling 350
the rad is new its a aluminim rad with new hoses and ok I will put the bottom shroud on
steps350 is offline
