68 camaro dual electric fans - Team Camaro Tech
post #1 of 8 (permalink) Old May 6th, 10, 08:13 PM Thread Starter
knightmoose's Avatar
car overheated today as the fans didnt turn on, im not sure why they didnt turn on after fooling with some wires etc the fans did eventually turn on and i drove it to work etc as the car didnt over heat again.
The issue is im concerned if the car over heated once than it will do it again, is there a way to rule out the sensor or switch module being the colprit? The fans work thus im thinking maybe i should replace the sensor oart of the set up?
it about helping others
knightmoose is offline
post #2 of 8 (permalink) Old May 7th, 10, 05:38 PM
Re: 68 camaro dual electric fans
check your connection at the fuse box, check the ground wire,
jjjcamaro is offline
post #3 of 8 (permalink) Old May 7th, 10, 05:46 PM
I'm thinking you have a bad connection or short.
68 Camaro~LSx ~all motor
post #4 of 8 (permalink) Old May 8th, 10, 06:16 AM Thread Starter
well it be to much to run a regular fan and 2 electric fans just in case the electric fans have a problem again this way at least you have a fan on to prevent over heating?
post #5 of 8 (permalink) Old May 12th, 10, 06:29 AM
I run duel fans one runs by the sensor aand the other runs off a switch in the car.Works great if the switch does not work the straight power to the other swicth works.
FastFred is offline
post #6 of 8 (permalink) Old May 12th, 10, 05:52 PM
foreverlookin's Avatar
I know someone that installed an override switch just in case that put power straight to the fans.
foreverlookin is offline
post #7 of 8 (permalink) Old May 12th, 10, 06:17 PM
Jeff
yellow69RS's Avatar
If you're doing this with out a relay make sure the switch will handle the load.
Jeff
yellow69RS is offline
post #8 of 8 (permalink) Old May 12th, 10, 07:44 PM Thread Starter
hmm the fans have been turning on lately etc , i think the maybe an alternative power source with a switch as you are suggesting will help just in case for back up power is a good idea, a basic auto electrician should be able to assist thanks.
