69 Camaro Overflow bottle location - Team Camaro Tech
post #1 of 6 (permalink) Old May 11th, 10, 06:01 PM Thread Starter
Can someone please post a picture of where their radiator overflow bottle is located on a 69 camaro small block. It been 6 years since I took it off, and I cant figure out where the thing gets bolted back on !!!!
Alzheirmers setting in ????
Thanks in advanace
efd75 is offline
post #2 of 6 (permalink) Old May 11th, 10, 06:40 PM
Kevin
KevinW's Avatar
Re: 69 Camaro Overflow bottle location
Its because there is none. 1st gens just had a thin wall tube from the rad cap straight down. If you are thinking about the washer fluid container, non-RS got it mounted next to voltage reg on rad support, RS was mounted to pass inner fender.
Kevin
KevinW is offline
post #3 of 6 (permalink) Old May 11th, 10, 07:27 PM Thread Starter
That explains it. Thanks
efd75 is offline
post #4 of 6 (permalink) Old May 12th, 10, 04:28 PM
Paul
Hi TC, anyone have a picture of the bottle on an '69 RS?
thanks, Paul
69rszee is offline
post #5 of 6 (permalink) Old May 13th, 10, 07:44 AM
click's Avatar
click is offline
post #6 of 6 (permalink) Old May 13th, 10, 04:55 PM
Paul
Thanks Click. Great picture.
69rszee is offline
