Overheat issues - Team Camaro Tech
post #1 of 13 (permalink) Old May 15th, 10, 01:45 PM Thread Starter
Ken
Overheat issues
Hey guys, just got my 69 on the road to find it overheats(230-240 deg) when driving after awhile(15miles odd). It is a zz502 with a gm serpentine system. I have been through all the common issues e.g. water pump spinning the right way(reverse cavitation), timing, fuel mix, t/stat failure etc.
I even bought another new premium radiator( full alloy) with a 16" thermo and it helped a little bit but still eventually overheats. I have now even installed a push thermo and fabrricated an air intake which sits under the valance to direct air straight into the radiator. I do have an a/c condensor about 2" in front of the radiator but this air intake feeds straight into the space between them so it should rule out any air turbulence caused by the condensor. Horrid thoughts of incorrect head gaskets blocking off water holes are a possibility but I hope not.
The only things I am thinking off is a possible flow problem with the serpentine kit(although when I pulled the top hose off it pumps the radiator dry very quickly), or a far out one like... I am running hedman shorty headers and had to clearance primaries 3 and 5 to fit around steering box, seeing as they are only 1 7/8" primaries the back pressure causing heat problems, far out I know but I am stumped. Any help would be great thanks, Ken.
chevguy is offline
post #2 of 13 (permalink) Old May 15th, 10, 07:07 PM
Re: Overheat issues
Having a large fan helps, 7-blade? Gotta pull air across the radiator to cool.
Might try a high flow thermostat rather than a standard thermostat.
Five hundred cubic inches generates alot of heat, especially at higher rpms, say 3000 rpm.
General rule of thumb, if it isn't puking, boiling over, it's not overheating.
Might also try a 22 lb rad cap. Radiators are tested to 50 PSI for integrity.
Radiator big enough? My OE Dually, 454, with A/C on, 34X17X3 alum rad still runs 230F.
Everett#2390 is online now
post #3 of 13 (permalink) Old May 15th, 10, 09:00 PM Thread Starter
Ken
Re: Overheat issues
Thanks mate might look at the t/stat, I noticed the relay was hot for the thermos so just wired up another one in conjunction, took the car for a drive and it now sits on around 200 so it`s looking good... we are in winter here though so it might be a little ordinary come summer.
chevguy is offline
post #4 of 13 (permalink) Old May 15th, 10, 10:12 PM
Steps
Re: Overheat issues
If driving around there is more air flow from the movement of the car than any fan will put thu....
If a cooling system is up to scratch, the difference between a frosty morning in winter and a hot summers day will only be marginal, 5 deg at most, and thats under load up a mountain.
Yep I think so to....drill a couple 3/16 holes se if that helps...also drop in a jug of water, boil up from cold with a thermeter...make sure it is opening all the way up at the correct temps
Dont assume a new thermostat works correct, its not un common these days to get faulty ones...read the fine print "made in china."
Steptoe is online now
post #5 of 13 (permalink) Old May 15th, 10, 11:18 PM
Re: Overheat issues
Are you sure the gauge is accurate?
400bird is offline
post #6 of 13 (permalink) Old May 16th, 10, 04:06 AM Thread Starter
Ken
Re: Overheat issues
Definately, laser checked the motor temp to confirm
chevguy is offline
post #7 of 13 (permalink) Old May 16th, 10, 06:12 AM
DT
Donny
DT's Avatar
Re: Overheat issues
Do you have the correct rotation fan??
DT is offline
post #8 of 13 (permalink) Old May 16th, 10, 07:58 AM
click's Avatar
Re: Overheat issues
I dont see you mention if you have a shroud too? If not, thats part of the problem. You need to have that shroud.
click is offline
post #9 of 13 (permalink) Old May 16th, 10, 02:27 PM
Steps
Re: Overheat issues
No shroud that WILL be a problem
post #10 of 13 (permalink) Old May 16th, 10, 02:36 PM
chris
Smile Re: Overheat issues
id try back flush maybe heater core is plugged thats if you have one.sure thermo is installed the right way? just my thoughts.
572BLOWN is offline
post #11 of 13 (permalink) Old May 16th, 10, 02:43 PM Thread Starter
Ken
Re: Overheat issues
It has a full shroud and no heater connected, triple checked thermo rotation. Thanks for the replies but after fitting the new thermo relays the motor seems constant now at about 200 deg, from looking on here and around it seems the 502`s seem to run at about this or a bit above. Thanks again for the help.
chevguy is offline
post #12 of 13 (permalink) Old May 16th, 10, 03:53 PM
Re: Overheat issues
Thermo relays control what?
post #13 of 13 (permalink) Old May 16th, 10, 08:31 PM
Dan
trackman's Avatar
Re: Overheat issues
x2
67 RS convertible
Mark Jones 496...690hp
Liberty modified TKO600
Holley HP EFI
trackman is offline
