Aluminum Radiator or Copper/Brass? - Team Camaro Tech
post #1 of 5 (permalink) Old May 15th, 10, 05:03 PM Thread Starter
I need a new radiator in my 69 Camaro and was ready to order an aluminum one from Summit when I was advised that I would be unhappy with aluminum and would be much better off re-coring the original even though that would be more expensive. Your thoughts please.
Chief48 is offline
post #2 of 5 (permalink) Old May 15th, 10, 06:18 PM
Skip
Skeeter55's Avatar
Re: Aluminum Radiator or Copper/Brass?
I got one of these becool-radiators for my 69 Camaro. Its a 4-core copper/brass only cause i didn't want the aluminum and it works awesome.
http://www.radiators.com/manufacture...-radiator.html
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 5 (permalink) Old May 15th, 10, 06:20 PM
Andrew
Andrew69's Avatar
Do you want original? Get your original recored.
Do you want a great cooling radiator for a reasonable cost? Go aluminum. Summit sells a bolt in aluminum radiator for our cars for about $300.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 5 (permalink) Old May 16th, 10, 03:18 AM
shane
if you want the worry of electrolysis/stray-currant always on your mind go for the aluminium. most copper brass radiators have been in cars for 30 + years. if a aluminium radiator gets a leak its going to the bin. you cant fix them .
if your stock rad is beyond repair and your going to get a new one regardless my opinion is get a copper/brass 4 core replacement.
gingerbreadman1977 is offline
post #5 of 5 (permalink) Old May 16th, 10, 02:32 PM
Steps
The orginal brass is way over built..will do everything an Al one will
It was cheaper for me to air freight a replacement radiator in from the West Coast US to NZ than get mine recored.
In my books an orginal looks far nicer in a 40 yr old car than a mordern Al, which looks out of place.
Steptoe is offline
