vintage air question - Team Camaro Tech
post #1 of 10 (permalink) Old May 17th, 10, 05:52 PM Thread Starter
Chris
hey guys, i had Vintage Air installed and am having some problems. after the antifreeze leak was fixed, it ran fine for about a week. But now, when i turn it on to air..it runs for about two seconds then it goes to a much lower speed for another two seconds, then i hear a click and it shuts off. Any suggestions? tx Chris
ejs4732 is offline
post #2 of 10 (permalink) Old May 17th, 10, 05:57 PM
Re: vintage air question
Is this the First Gen vintage install? When you hear the click, is the compressor shaft turning ? ie, clutch engaged? Temp control knob almost all way to right?
TC # 349
zdld17 is offline
post #3 of 10 (permalink) Old May 17th, 10, 06:04 PM Thread Starter
Chris
its gen 4, after the click everything for the air turns off, temp control is slid all the over way for cold
ejs4732 is offline
post #4 of 10 (permalink) Old May 17th, 10, 06:35 PM
Sounds like auto fan control problems, not normal for first gen. Didnt know Vintage offered anything for 4th gen camaros. Sorry, I cant help. Maybe someone else had done this.
TC # 349
zdld17 is offline
post #5 of 10 (permalink) Old May 17th, 10, 08:40 PM
I think he was stating it was the Gen 4 A/C kit for a first gen camaro. Is the click coming from the compressor clutch or the fan motor?
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #6 of 10 (permalink) Old May 19th, 10, 08:44 PM Thread Starter
Chris
Thats right Scott, its in a 68. the click sound, sounds like the fan motor under the dash on the passenger side.
ejs4732 is offline
post #7 of 10 (permalink) Old May 20th, 10, 05:37 AM
foreverlookin's Avatar
Chris, have you re-done the control panel recalibration?
foreverlookin is offline
post #8 of 10 (permalink) Old May 20th, 10, 04:55 PM Thread Starter
Chris
Steve, if i had the slightest idea what that meant i would've given it a shot :-)...on a serious note, it was installed by a builder who isnt nearby and i dont know much about the system...sounds like i'm heading to Stans Restoration in lexington, NC...what exactly would a control panel recalibration involve..is it something an old motorhead with limitd recent experience can do?
ejs4732 is offline
post #9 of 10 (permalink) Old May 20th, 10, 04:56 PM Thread Starter
Chris
steve, just saw your link, thanks, Chris
ejs4732 is offline
post #10 of 10 (permalink) Old May 21st, 10, 05:50 AM
You can get all of the technical stuff from Vintage airs web site under downloads. Good to have just in case. And yes Chris you should have no problem doing it yourself.
