running hotter - Team Camaro Tech
post #1 of 9 (permalink) Old May 18th, 10, 08:24 AM Thread Starter
Big daddy
Question running hotter
I installed va,it works good,but since I put it in,the car runs hotter.Not while idling but while drving.While sitting,it runs at 180,while driving with ac off it goes to 190-195.I has a new alum rad taurus elec fan.Whats up?
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 9 (permalink) Old May 18th, 10, 08:29 AM
Bri
bwcamaro68's Avatar
Re: running hotter
You replaced your stock radiator with a multi core(ac in side) radiator?
you might of been better off with a separate radiator and ac cooler. Do you know what your thermostat is rated at?
What is the radiator core size?
Just a few questions to help figure out your issue.
"Three Rules of Work: Out of clutter find simplicity; From discord find harmony; In the middle of difficulty lies opportunity."
Albert Einstein
"Never Forget" FDNY 9/11/01
I have more than 4 Camaro's am I Addicted?
bwcamaro68 is offline
post #3 of 9 (permalink) Old May 18th, 10, 08:39 AM Thread Starter
Big daddy
Re: running hotter
It is adirect fit summit rad,the ther is 180.It was not running this hot before adding va.
carhodge is offline
post #4 of 9 (permalink) Old May 18th, 10, 10:02 AM
Re: running hotter
190-195 isn't hot at all.
How much vacuum advance did you add?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #5 of 9 (permalink) Old May 18th, 10, 11:14 AM Thread Starter
Big daddy
Re: running hotter
So,what is hot?I thought that 200 or so was.I have 98 vet and they run about 210 normally.Fans don't come on until 230.
carhodge is offline
post #6 of 9 (permalink) Old May 18th, 10, 11:54 AM Thread Starter
Big daddy
Re: running hotter
None,been the same as b4 adding ac.
carhodge is offline
post #7 of 9 (permalink) Old May 18th, 10, 11:56 AM Thread Starter
Big daddy
Re: running hotter
if 190-to 195 is not too hot then I'll just watch it.Car run very good.
carhodge is offline
post #8 of 9 (permalink) Old May 18th, 10, 01:06 PM
steve
Re: running hotter
my 540 is the opposite u unplug the va and it runs hotter while at idle
stevie is offline
post #9 of 9 (permalink) Old May 20th, 10, 10:09 AM Thread Starter
Big daddy
Re: running hotter
ok,I found the problem,looks like it was the timing.Don't know how it happend,but some how the timing was retarted.Retimed and all is well.
carhodge is offline
