1969 Radiator Tank Code? - Team Camaro Tech
post #1 of 3 (permalink) Old May 18th, 10, 08:43 PM Thread Starter
Dean
The radiator in my numbers matching 69 L48 has " CF " for an end tank code right under the " fill to here cold " . the CRG codes don't show this code at all but it looks just like the codes in the pictures, it fits the car perfect and looks to be original.
Anyone know what this code means or if it's even a GM radiator??
440sixpack is offline
post #2 of 3 (permalink) Old May 19th, 10, 03:45 AM
parkbrau's Avatar
Re: 1969 Radiator Tank Code?
Dean, I think you might have a replacement radiator. I googled it and it came up with a Buck Skylark????
parkbrau is online now
post #3 of 3 (permalink) Old May 19th, 10, 09:29 AM Thread Starter
Dean
I don't get it, it fits perfect and looks EXACTLY like the pictures of proper 69 small block camaro radiators I've looked at, mounting brackets too and shroud too.
I guess since it seems correct in every way other than the code I'll just get it recored and use it.
