where to mount temp sender - Team Camaro Tech
post #1 of 12 (permalink) Old May 23rd, 10, 04:32 PM Thread Starter
Paul
Ok looking for ideas- maybe a pic or 2
i'm running a rpm(performer) manifold on my sbc and my temp sender is in the front drivers side of the manifold. well i wanna add an electric fan should i "T" off the one hole and run both sensors from the same outlet or does someone else have a different idea. Heads are aftermarket alum and no provisions for a sensor. thanks
"Lets Ride"
Pauly is offline
post #2 of 12 (permalink) Old May 23rd, 10, 05:18 PM
Ted
Re: where to mount temp sender
Paul, does your intake have 2 ports for temp senders? Otherwise you can use the heads also. There are ports there.
tgifford5 is offline
post #3 of 12 (permalink) Old May 24th, 10, 03:59 AM Thread Starter
Paul
only one and the heads do not
"Lets Ride"
Pauly is offline
post #4 of 12 (permalink) Old May 24th, 10, 04:03 AM
BILL
SPARKY69's Avatar
one temp sender for the guage and one for the fan..
one on the intake and one on the water neck?
what kind of heads are you running?
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 12 (permalink) Old May 24th, 10, 06:43 AM
Temperature senders should not be "T'd" from the same port, the sensor will never read the correct coolant temp.
The alum heads should have an unmachined boss in the same location as the OE heads.
Either you drill and tap for the sensor or have a machine shop do it.
You can get a thermostat housing with a plug in it and use it for the fan thermostat.
Everett#2390 is online now
post #6 of 12 (permalink) Old May 24th, 10, 10:21 AM Thread Starter
Paul
^ great idea didnt think of that(in the waterneck) thanks everett
"Lets Ride"
Pauly is offline
post #7 of 12 (permalink) Old May 27th, 10, 06:49 AM
http://hotrodchrome.com/waternecks/3110.jpg This looks like a cheapO you can get factory GM ones like this.
msicks is offline
post #8 of 12 (permalink) Old May 27th, 10, 01:29 PM
Count on that o-ring to leak. Sand the chrome on the mating surface and use sealant. I've even left the o-ring and used sealant. No leaks either way.
Sauron67MM is offline
post #9 of 12 (permalink) Old May 28th, 10, 04:56 AM
Guess
HwyStarJoe's Avatar
Chrome bad!
HwyStarJoe is offline
post #10 of 12 (permalink) Old May 28th, 10, 05:26 AM
I just worked through this. Please take a look at post below...
https://www.camaros.net/forums/showthread.php?t=178136
Clean 67 - 600hp / 579ft lb, 502
St Petersburg, FL
mccomas is offline
post #11 of 12 (permalink) Old May 28th, 10, 05:51 AM
ZZ_430's Avatar
It doesn't make any difference.
Think how fast that coolant is moving through the motor.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #12 of 12 (permalink) Old Jun 2nd, 10, 04:35 PM
Danny
for my electric fan i ran one of those probes that go through the radiator fin and it works pretty well and it's adjustable. just another option for you
Danny
1968 Camaro
2002 S2000
68Elmo is offline
