my 67 needs some help - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 6th, 10, 06:17 PM Thread Starter
I have a 67 camaro with a T&L 408ci stroker and a TKO600 tranny.
It seems to be running a little hot. It was about 85 out today and i took it out and it was at about 210. It has a GM big block radiator, edlebrock water pump, shrouded mechanical fan, and a 160 degree thermostat.
is 210 too hot?
what do you suppose it is or can i have a link to a troubleshoot?
Thanks a lot
67 Camaro
67speeda is offline
post #2 of 5 (permalink) Old Jun 7th, 10, 01:32 PM
Smile Re: my 67 needs some help
Is your sending unit in the head or in the intake man? If it,s in the head, it runs a little hotter
67 Plain Jane is offline
post #3 of 5 (permalink) Old Jun 12th, 10, 08:46 PM Thread Starter
it is in the intake
67 Camaro
67speeda is offline
post #4 of 5 (permalink) Old Jun 13th, 10, 01:09 PM
Was the car getting warm while cruising or sitting idle?
210 is not too hot, but with a 160 stat the temp should get up to 160ish and stop.
400bird is offline
post #5 of 5 (permalink) Old Jun 15th, 10, 06:10 AM
Charlie
I would start by replacing the 160 with a 180. 160, IMHO, is too cold. You say it was running around 210, was thus on the highway or city streets? City street, as long as fan brings back down, then ok. If highway, then bad, but you really need to start with replacing the stat. Also, check the cap. Are you running an open or closed system? If closed, then the cap will have 2 rubber seals on it. 1 to seal the system for pressure and the 2nd is to seal the cap to the rad so the fluid won't leak out when the fluid goes to the overflow bottle. If the cap is old, the seal that allows pressure to build gets a groove in it and allows the pressure to leak, causing the boiling point to lower and causing the system to run hot. If all this checks out, are you running a fan clutch or flex fan? If you are running a fan clutch, is it a thermal or non thermal style? I thermal, then the bi-metal spring on the clutch that senses how hot may be bad or it may be the clutch itself. If you are running a non thermal clutch, you may want to switch to a thermal. It will help with fuel mileage.
67CamaroRS/SS is offline
