Fan blows less on high - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 19th, 10, 07:34 PM Thread Starter
blake
My blower fan blows less on high than medium. I replaced the fan relay and that didnt help. The plug next to the relay I took it out to look at and it had two wire coils but they arent burnt into what does this do anybody know? And what else could be my problem?
soonerfanru2 is offline
post #2 of 7 (permalink) Old Jun 20th, 10, 12:30 AM
parkbrau's Avatar
Re: Fan blows less on high
Swap out the fan control switch. Good chance that's the problem.
parkbrau is offline
post #3 of 7 (permalink) Old Jun 20th, 10, 04:27 PM Thread Starter
blake
is this an over the counter part or will it have to come from one of the vendors on here? the switch in the dash is what you are talking about right?
post #4 of 7 (permalink) Old Jun 21st, 10, 09:27 AM
parkbrau's Avatar
heres the links to ricklers for it. 67 right?
http://www.rickscamaros.com/camaro-h...1967-1968.html
parkbrau is offline
post #5 of 7 (permalink) Old Jun 26th, 10, 11:28 AM Thread Starter
blake
Thanks for the link i will try it. what all do i have to remove to get to the switch?
post #6 of 7 (permalink) Old Jun 28th, 10, 06:59 AM
Michael
parkbrau,
Wow, the Holy Grail of the 1967 AC system (except for maybe the vacuum switch to kick in the compressor). They could have charged $100 (please don't charge $100).
Thanks,
Michael
mahunt is offline
post #7 of 7 (permalink) Old Jun 30th, 10, 07:38 AM
I have had this problem about 3 or 4 times on 2 different Camaro's. It never turned out to be the switch on the a/c control panel. I would check out this tread below, it may be something simple like the in-line fuse, or a bad ground. The last time it happened to me, I think it turned out to be a bad ground wire pertaining to the relay on the suitcase.
https://www.camaros.net/forums/showth...ht=blower+high
327!275hp!Convt! is offline
