lt1 coolant cross over tube help guys plz! - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 23rd, 10, 09:42 PM Thread Starter
Reade
hey guys i finialy got my 93 lt1 running in my 68! i have allot of coolant hoses caped (oil cooler/throttle body) for now i just test started it in the drive way for a min, im using my stock 68 radiator but i dont know ware to put the hose for the crossover tube on the back of the heads. i hear some people say to thread it into the thermostat housing (lower hose) and others say to put it in the upper hose (driver side) can some 1 please tell me ware it should go and why please.
Rg68lt16spd is offline
post #2 of 5 (permalink) Old Jun 23rd, 10, 10:58 PM
T-Bone's Avatar
Re: lt1 coolant cross over tube help guys plz!
Hey cool: I'm running a '95 LT1 in my '68.
I think the hose from the crossover on back of the heads feeds into the radiator near the cap (passenger side). (I'm running a '95 Camaro radiator so it plugs right in.) The hose goes to a connection on the radiator near the cap.
So, you ought to be able to connect it to the upper hose, which goes to the same side of the radiator as the crossover hose (on mine).
Check this:
http://shbox.com/1/93-94_hoses.jpg
Shoebox's web site is INVALUABLE when doing LT1 work.
Check:
http://shbox.com/1/4th_gen_tech1.html
Good luck!
...late update - it looks like 93-94s dump the crossover to the driver side of the radiator, and the 95-97s dump to the passenger side, so you should be able to connect to either upper or lower hose OK.
T-Bone is offline
post #3 of 5 (permalink) Old Jun 24th, 10, 07:28 AM Thread Starter
Reade
i dont have a lt1 rad just using the stock 1 has no hookups. i see people put the hose the the bleeder valve on the thermostat and others on the driver side upper hose
post #4 of 5 (permalink) Old Jun 24th, 10, 12:05 PM Thread Starter
Reade
ok i see what to do now i see on the diagram im going to tap a hole in the pump and put it to the upper hose so it will feed back into the rad. like this guy did http://www.pro-touring.com/forum/sho...d.php?p=449259 seems to be simple and effective.
post #5 of 5 (permalink) Old Jul 5th, 10, 03:13 AM
joe
LT1 in my 68 is tapped into the top of the thermostat housing just like the above post
balljoint is offline
