vegas heat, car running hot - Team Camaro Tech
post #1 of 28 (permalink) Old Jun 29th, 10, 08:52 PM Thread Starter
daniel
ive been having a problem with my car running hot since last summer. This summer i have AC and the car runs even hotter. around the city it will climb up to 210 215 and i have to shut it off at stop lights and run the fans to try and cool it. On the freeway it was running at 210 without AC, if i turned on the AC it would start climbing instantly. When the car gets hot my air to fuel mixture gauge says its running really rich and the car will stall if i dont play with the throttle
i have a march 1 serpentine system, stainless steel braided fuel lines from classic, mechanical fuel pump, phenolic carb spacer, and a demon carb, and a big block aluminum radiator w/ two 11.5" spall fans w/ a shroud.
the motor is a 350 from a 69 truck. it has the edlebrock performer RPM kit and was dynod at 420 at the fly wheel and 315 to the wheels.
67 ss350 clone under restoration
danyboy1409 is offline
post #2 of 28 (permalink) Old Jun 29th, 10, 10:25 PM
Steps
Re: vegas heat, car running hot
Bottom hose renforcing spring ok? cant squeeze the hose up?
Shroud and fan ok? fan postioned right in shroud...have a shroud?
Thermost working correct, dont assume a new thermosts works...check in jug of water as it heats up..it opens and opens all the way....and correct thermostats diameter hole when open...and has bleed hole....and correct temp rating?
Radiator cap working correct and right pressure?
Checked the calibration of the gauge in a jug of water as the water heats up?
Steptoe is offline
post #3 of 28 (permalink) Old Jun 30th, 10, 02:48 PM Thread Starter
daniel
bottom hose is good i cant squeeze it.
the shroud is a flat piece of aluminum with two cut outs for the fans. how are fans supposed to be positioned?
we have tried everything, right now it is running hot with no thermostat and a restricter plate inplace.
the radiator cap is 7 psi, i recently read it is suppose to be 20 psi. would that make a difference?
post #4 of 28 (permalink) Old Jun 30th, 10, 04:31 PM
Ozzie
Danyboy, heck yeah it makes a difference! I think I read on this site that the pressurized radiator cap value gives you double the amount in terms of temperature. In other words: I have a 16psi cap on my radiator. That means my system would not suffer boil over until 244* F (212 + 32) So even going from your current 7psi cap to a 16psi would give you 18* of leeway before trouble strikes.
Now, none of this solves your running hot condition. On very hot days out here in California, my car gets up to 195-200* - and almost never any hotter. You still have some tweaking to do to get your normal running temps down.
'68 Camaro RS
zz383 (2005) rebuilt in 2019
AFR 195s, Quick Fuel 680, 700r4, Detroit TruTrac 3:42s
fastercar68 is offline
post #5 of 28 (permalink) Old Jun 30th, 10, 04:57 PM
Steps
Covered in many older threads....shroud type and where the fan sits....get it wrong and it will run hot.
Cap...from memory the orginal was a 15lb anything from a 12 to 16lb we have found works well...going higher stresses the radiator..it is not the pressuew that stresses but the pressure twisting the radiator that causes metal fatigue....lay a raditaor on the bench, then presure test, you will set it 'warp'
AND DONT ***-u&me the gauge reads right....
Dro the sensor in a near full electic jug of cold water...connect the temp gauge lead to it and ground the body of the sensor to the car
heat up the jug, with a thermeter in it and compare with what is on the gauge
Testing themostats basically the same but no wires connected.
Important, do it when the missus is out...other wise you will be in deep poo.
And wash oput well with dishwash machine powder and rinse well, otherwise the salightest bit of oil left in the jug makes your cup of coffee taste like crap.
Steptoe is offline
post #6 of 28 (permalink) Old Jun 30th, 10, 06:22 PM
DT
Donny
DT's Avatar
Sounds like you have an airflow problem. Check serpentine system and fans. Make sure they are installed correctly. Electric fans can either "push" the air or "pull" the air through the radiator. On some fans all you have to do is reverse the positive wire, meaning make the postive wire the negative wire and the negative wire the postive wire in order to change the direction of airflow.
DT is offline
post #7 of 28 (permalink) Old Jun 30th, 10, 10:24 PM Thread Starter
daniel
ya the aluminum radiator i have says that an 18psi cap should be ran. tomorrow i will go and put a different cap on.
so the fans should be only sticking halfway out the shroud correct? i can have a friend make me one if i need it.
also the fans are in the right direction, i think. i feel the air blowing towards the engine.
i thought the radiator may be clogged with some rust or something, even though its new the motor is not. so i took it out and let it sit over night with some CLR in it and i believe i got some crud and crap out today. i threw in the radiator today and tomorrow i will take it for a drive and see if that makes a difference.. also i put in a 195 stat, does that seem about right for vegas heat?
post #8 of 28 (permalink) Old Jul 1st, 10, 04:02 PM
DT
Donny
DT's Avatar
Put a 160 degree thermostat in it.
DT is offline
post #9 of 28 (permalink) Old Jul 2nd, 10, 05:00 PM
Frank
Most 11" fans are borderline sufficient in normal heat. In Vegas heat, your most likely under faned.
There are multiple fan designs, hopefully you at least have the high performance 11s (almost 3" thick)
Post a pic of the fans and shroud.
Besides that, put a thermostat in it, but I would actually go a 180, a lower temp stat will just stay open all the time and never let the water stay in radiator long enough to cool the water.
Is your March set up a horsepower kit or high flow water kit?
ProdigyCustoms is offline
post #10 of 28 (permalink) Old Jul 20th, 10, 11:07 AM Thread Starter
daniel
http://www.marchperf.com/styletrack_sb.html this is the serpentine system i have, i was told that it has a high flow reverse rotation corvette water pump.
VA03-AP70/LL-37A (11" HP) this looks like the fans i have, i measured the fans and from radiator to the center tip of the fan is about 3 1/4-1/2".
i finally took the car for a drive the other day and it seemed to do pretty good, it never went above 210 and it stayed around 200-205 and when i got on the freeway it cooled down to 190, the temp outside was 112 and the AC was blasting. but i did have a problem, the car when it warms up begins to run very rich and floods out the motor. the car stalled at a stoplight and didnt want to start and when it finally did a white colored smoke came out the exhaust. does anyone else have this problem of the fuel getting hot, i have it routed in the stock location, but the exhaust going over the rearend may be closer than normal?
i just read something that drilling a hole in the gas cap may help the problem since it would let air in and out instead of just letting the air in? (i have vented gas cap)
post #11 of 28 (permalink) Old Jul 20th, 10, 12:26 PM
Lex
Lexlas's Avatar
Where i live it gets to be about 103 hot at times, my 68 runs at 190 - 210 at times too. I believe there is a special coolant that is made for cars that run in hot weather and it is suppose to keep your engine running allot cooler. I have yet to try this, and i am not running AC. I saw this special coolant in a Chevy magazine for Camaros also. I will add a link when i find it. Running at that temp my Camaro has never stalled but i can imagine with AC running it would. I drove to another city where the temp is normal like 70 and my camaro was luving it. I hate these hot cities but houses were cheaper, lol ..
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #12 of 28 (permalink) Old Jul 20th, 10, 02:21 PM
Steps
Yes...this is the stock thermostat temp...and make sure you get the 180 for chev SB there are 2 GM thermostats the std one and a "high flow" one..I would start with the std one 1st.
This will not 'solve' the issue unless the 190 you have in (which will be a non GM not for a SB...maybe for a toyota or something) doesnt have the flow charactoristics that the sb needs.
And always check the new thermost in a jug and thermometer before installing.
Steptoe is offline
post #13 of 28 (permalink) Old Jul 20th, 10, 02:54 PM Thread Starter
daniel
i forgot to add that i did throw in a high flow 180 stat before the last test drive, but i had a 195* stat in before not 190*. Im going to wrap the fuel line with a heat radiant tape and see if that helps.
post #14 of 28 (permalink) Old Jul 20th, 10, 04:29 PM
Todd
Check your bowl levels. If they are a little high the heat may force the fuel into the venturis. Also, run a 70% water/30% coolant ratio as long as you don't plan to go to a cold climate. It's tough to keep these babies cool. It's ****** hot.
Vegas69 is offline
post #15 of 28 (permalink) Old Jul 20th, 10, 10:30 PM Thread Starter
daniel
i just got back from driving and it was running really rich under acceleration but at idle it was good right around 12.7-13.2 on my AF gauge. and it did flood out and die a couple times. i just checked the bowls and i cant see in any in the front one and the back one was just under half way. i got a hold of the guy who tuned the motor and im going to go see him in a couple weeks to see if maybe he can do something. i checked the timing and it was 40* total advance, idk if thats common but we'll see.
