Cooling system capacity - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 27th, 10, 02:40 PM Thread Starter
Jack
Smile Cooling system capacity
Anyone know the cooling system capacity for a 69 Camaro 350 w/ac
I can't find in my old manual and need it to find the amount of antifreeze to use. (any antifreeze tips)
JVFCamaro is offline
post #2 of 10 (permalink) Old Jul 27th, 10, 06:15 PM
Re: Cooling system capacity
Cooling system is 17 quarts. I use Peak 50/50 mix.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #3 of 10 (permalink) Old Jul 28th, 10, 06:17 AM Thread Starter
Jack
Thanks for the info
post #4 of 10 (permalink) Old Jan 12th, 16, 03:47 PM
Would this be the same capacity as a '68, with a 327, 2bbl carb? Thanks
Troutslayer is offline
post #5 of 10 (permalink) Old Jan 12th, 16, 04:11 PM
I like the 50/50 pre-mix stuff also....at least you know the blend is right
BUT, if you plan to mix yourself....be sure you use distilled water, not tap or hose
68 Camaro~LSx ~all motor
post #6 of 10 (permalink) Old Jan 13th, 16, 04:22 AM
This is crucial in my book. Having had my fair share of diesel engines apart and seeing how tap water leaves deposits out of the water baked around liners, I won't use anything but distilled water in my cooling systems. What's a gallon of distilled water cost.... less than a $1?
buenymayor is offline
post #7 of 10 (permalink) Old Jan 13th, 16, 04:51 AM
kevin
when I bought my champion radiator I was told not to use well, city, or distilled water, but to use drinking water purchased from walmart
flat tire is offline
post #8 of 10 (permalink) Old Jan 13th, 16, 05:44 AM
Vega$69's Avatar
50/50 is not ideal for cooling. Great for freeze protection
Pure water is best but you do need coolant for pump lubrication and anti corrosion.
50/50 gets you freeze protection to -37* F which very few if any of our cars will ever see.
I run 30/70 which gets freeze protection to -17*
Boil over temp is also increased slightly with higher percentage of coolant however this increase doesn't mean much in a pressurized system.(pure water boils at 250* in a 15 psi system)
"You should only use as much anti-freeze as is necessary for your climate and operating conditions"
ANTIFREEZE % WATER PROTECTION AGAINST FREEZING *PROTECTION AGAINST BOIL-OVER
30 70 -17C 121C
40 60 -23C 126C
50 50 -37C 129C
60 40 -52C 132C
70 30 -64C 136C
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 10 (permalink) Old Jan 13th, 16, 01:32 PM
Bill
I have found that once the system is empty, add two gallons of antifreeze and then two gallons of water, until full.
arocars is offline
post #10 of 10 (permalink) Old Jan 13th, 16, 01:39 PM
While I do agree.... My garage isn't climate controlled
Lil' extra protection too
