what e-fans are you guys running?? - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 27th, 10, 06:47 PM Thread Starter
Send a message via AIM to joyride_
my dad finally wants to get rid of his flexfan for an e-fan setup like i have on my s10 xtreme...
and his stock radiator is so small...he has no cooling issues at all right now, but wants to free up some hp by doing any lil' thing here and there that he can...
i'm currently running a ford taurus fan on my truck with a built 4.3...and it does the job more than fine...and it would fit in his just fine...but it's mine, so he can't have it. lol...
wondering what ones you guys are using....especially people w/ their stock radiators, or aftermarket ones that are the same size i guess...i've been searching craigslist and ebay and i found a lincoln mark VIII, that says it has 4300 cfm...i have no idea how much that is, but seems to be more than the others i have found...lol
his shows 22x19x5...i rounded up on each of those...
i've searched as well but i would rather just like to get an idea of which ones would work and cool enough, especially for a drag race motor. he is estimating he has 540 hp motor, not to the ground.
thanks again, brian.
MY RIDE
01 S10 Xtreme 2/3 drop, BUILT 4.3L v6, 5spd
DADS RIDE
69 Camaro 500+ hp 355, t400, currie ford 9inch 4.56 gears, 100 shot
joyride_ is offline
post #2 of 12 (permalink) Old Jul 27th, 10, 08:30 PM
Ted
Re: what e-fans are you guys running??
What's this going into? Many options available. Depends on what he wants to spend. And the look he is after. Many things through summit and jeg's. I am running the Entropy BB aluminum radiator with dual spal fans bought through ebay. Total cost about $720 including wiring harness and shipping. I don't have any issues with over heating but mine is not in a drag race setup. Sorry didn't pay attention to your infor at the bottom of your post. But check out the hp rating of the Entropy. It is a nice unit. Iam not at the hp as your fathers cars but it will work and fit to his core support. Just need some well nuts and the upper radiator hose for a 68 with a/c.
Last edited by tgifford5; Jul 27th, 10 at 08:36 PM. Reason: Correction and additional info.
tgifford5 is offline
post #3 of 12 (permalink) Old Jul 27th, 10, 09:53 PM Thread Starter
69 camaro...he isn't looking at spending alot. haha that's for sure.
MY RIDE
DADS RIDE
joyride_ is offline
post #4 of 12 (permalink) Old Jul 28th, 10, 03:47 PM
george
I run dual spals,but have cooled many a big block with Flexalites Black Majic fully shrouded single fan on small core surfaces.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #5 of 12 (permalink) Old Jul 28th, 10, 09:55 PM
Put that flex fan in the bin and buy an OE 7 blade clutch fan.. It'll move more air than any e-fan too.
As the name says, "flex" fans don't push air, instead they flex. What's the point in that? They're like using a rubber wrench.
BlackoutSteve is offline
post #6 of 12 (permalink) Old Jul 29th, 10, 05:05 AM
I run a lincoln mark VIII on my 427 SBC with a 4 row brass radiator and it cools great even setting in 95 deg temps. It moves alot of air and it is wired for low and high speed but never gets to high speed.
Riley is offline
post #7 of 12 (permalink) Old Jul 29th, 10, 07:24 AM
Bryan Hall
another one for the lincoln mark viii fan on a 4 core rad...
My car pics...
dallas car show pics plus some of the cars i am building at work
importkiller69ss is offline
post #8 of 12 (permalink) Old Jul 30th, 10, 08:36 PM
The taurus fan works, I have one. Just get a junk yard one.
The Mark VIII fan may be too deep for a big block. I think the taurus may clear.
A big block radiator is the biggest radiator that fits easily, summit sells an aluminum piece thats fairly nice.
400bird is offline
post #9 of 12 (permalink) Old Jul 31st, 10, 09:23 AM
Bill
bill3337's Avatar
I have to agree with the seven bladed OE steel fan. When I was having heating problems I tried them all......from Spal to Zirgo and all the flex fans I could find as well as all the 'water wetter" products. I tried the 4 bladed OE fan as well, and that helped, but not enough. I switched to the seven bladed OE fan and that did the trick. I have to admit though that the biggest issue with over heating is usually in the engine, not in the fan, as it was in my case, but the 7 bladed fan solved my problem till I figured out the real problem in the engine.
bill3337 is offline
post #10 of 12 (permalink) Old Aug 9th, 10, 04:32 PM Thread Starter
alrighty...well...we just went and got a taurus 3.8l fan...and it seems as if it's a puller, and doesn't look like the taurus fan im using which works fine on my s10 w/ a built v6...
will this puller fan work or should i return it for hopefully the one i got, which i assume is the 3.0? im not sure...
400bird, do you by any chance know what yr your fan came off of, and if its a 3.8 or 3.0?
thanks for the help too all, appreciate it.
MY RIDE
DADS RIDE
joyride_ is offline
post #11 of 12 (permalink) Old Aug 9th, 10, 05:53 PM
Well, mine is a puller, but I don't remember for sure which engine the donor had.
If you search some old posts you should find the answer, probably 3.8.
400bird is offline
post #12 of 12 (permalink) Old Aug 10th, 10, 12:50 PM Thread Starter
thanks...we're just gonna go with it. it seems nice. it spins hard when its working...now im having an issue wiring it up..?
EDIT : got it running right and its fine now w/ the toggle switch we have it setup with...appreciate the help everyone!
MY RIDE
DADS RIDE
joyride_ is offline
