carpet wet under glovebox - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 30th, 10, 04:49 PM Thread Starter
Larry
I have a 2000 pontiac bonneville and I am having problems finding the a/c drain line under the car. I was told it was stopped up and I could use a clothes hanger and clean the drain line out. Please help me?
IT KEEPS ME GOING
69 Z/28
711 67 67
02D X33
69Z28X33 is offline
post #2 of 10 (permalink) Old Jul 30th, 10, 05:26 PM
Vintage 68's Avatar
Re: carpet wet under glovebox
Need to jack up the car and look up near center of firewall above the steering rack.
It's a black 'rubber' cap with the ends kind-a pinched together.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 10 (permalink) Old Jul 30th, 10, 08:11 PM Thread Starter
Larry
Thanks John
IT KEEPS ME GOING
69 Z/28
711 67 67
02D X33
69Z28X33 is offline
post #4 of 10 (permalink) Old Jul 30th, 10, 08:29 PM
Jeremiah
Its approx 6" to the right of the #8 spark plug on the underside of the evaporator housing. A black quarter sized rubber grommet with one end pinched down and a spring clamp retaining it to the evap housing.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #5 of 10 (permalink) Old Jul 31st, 10, 08:47 AM
Vintage 68's Avatar
Talking Re: carpet wet under glovebox
Originally Posted by Jeremiah View Post
Its approx 6" to the right of the #8 spark plug ...
Silly me - I thought they only put V-6's in 2000 Bonnevilles
1968 Convertible
Some trucks
post #6 of 10 (permalink) Old Jul 31st, 10, 08:57 AM
Jeremiah
Originally Posted by Vintage 68 View Post
Silly me - I thought they only put V-6's in 200 Bonnevilles
Guess I should pay better attention to what im reading!
Jeremiah is offline
post #7 of 10 (permalink) Old Jul 31st, 10, 09:08 AM
Vintage 68's Avatar
Wink Re: carpet wet under glovebox
Say whaa..
(edit) you posted back while I was
It's a "2000 Pontiac Bonneville"
They're transverse mounted V-6 front drive - there is no "#8 spark plug" ...
1968 Convertible
Some trucks
post #8 of 10 (permalink) Old Jul 31st, 10, 10:24 AM Thread Starter
Larry
You both are wrong. It's not at the firewall. I was under the car and looking for it by the firewall a long time and when I was about to give up, I looked to the rear and saw the 2" long rubber grommet hanging down under the right rear floor board. I worked with it a little and about a gal. of water drained out.
Now the fan dosn't come on. I checked the fuses, they are ok. Maybe the relay in the fuse box.
IT KEEPS ME GOING
69 Z/28
711 67 67
02D X33
69Z28X33 is offline
post #9 of 10 (permalink) Old Aug 1st, 10, 08:33 AM
Vintage 68's Avatar
Red face Re: carpet wet under glovebox
Originally Posted by 69Z28X33 View Post
... about a gal. of water drained out.
Now the fan dosn't come on ...
Well there's your problem - you've gone and drained the hydro-converter for the fan now
Sorry about the miss-lead ...
I had a 1999 Bonneville SSEi and the same problem with the condensation backing up with it.
Dealer corrected it once and I did it a few times after that.
Probably with the Pontiac 6000LE that had the same idiocyncracy
Hated that smell in the car
1968 Convertible
Some trucks
post #10 of 10 (permalink) Old Aug 2nd, 10, 08:11 PM Thread Starter
Larry
[QUOTE=Vintage 68;1460476]Well there's your problem - you've gone and drained the hydro-converter for the fan now
John- you had me going for awhile. man I thought I had screwed up. I'm sorta like the turtle, I'm slow but I'll get there eventually.
IT KEEPS ME GOING
69 Z/28
711 67 67
02D X33
69Z28X33 is offline
