Vintage Air Kit 67 Camaro - Team Camaro Tech
post #1 of 25 (permalink) Old Aug 18th, 10, 08:05 PM Thread Starter
Andy
Send a message via AIM to 67SS&99SS
I have been doing some reading on the vintage air kits for a while now and it seems like everyone is saying that the gen IV kit is the way to go. Does anyone have any pictures of this kit installed in a 67? My car would need a drivers side compressor so I would like to see a few pics of setups like this if possible. For anyone who has one of these kits installed, how do you like it? Can you use the factory type controls with the gen IV setup or do you have to use a different type controller? I like the look of the factory controls in my car, so I would like to stick with it, if possible.
Do any sponsors on the site sell these kits?
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #2 of 25 (permalink) Old Aug 19th, 10, 05:29 AM
Ted
Re: Vintage Air Kit 67 Camaro
Frank with Prodigy Customs has sold many to us members. I have a 69 and am installing it now, so I don't have pictures for you. But I know at least for mine you can use the factory controls. You have electrical connections instead of cables. But it is all in the kit with pictured instructions. I'm sure there are other vendors here also. I just got mine from Frank.
tgifford5 is offline
post #3 of 25 (permalink) Old Aug 19th, 10, 07:41 AM
foreverlookin's Avatar
I suggest you go to: http://www.vintageair.com/downloads.asp
and look at the installation information. Yes you use the original controls as they are modified to work with the Gen4 system
As stated above Frank at Prodigy is likely the most knowledgeable person to talk to as he has done a ton of installations and is a dealer for them....I bought my system from him and he helped out big time on getting it installed.
foreverlookin is offline
post #4 of 25 (permalink) Old Aug 19th, 10, 01:41 PM
Frank
Thanks for the kind words guys.
Yes the Gen IV will use your original controls and we provide a new placard for the face of the control with the proper comands. Pretty slick set up.
As for drivers side compressor mount, you must have a long water pump 69 and up style bracket kit?
On the drivers side compressor mount cars I like to substitute some extra long hose so you can make the hoses disappear and run from your compressor down and to the bottom of the radiator support and then run across the lower support and back into the engine bay instead of criss crossing the engine with big hoses.
I also like to use factory style reproduction vents on the 67s which I think are some of the coolest vents ever. I love those big 67 / 68 chrome vent balls.
We can set you up with everything you need to do the cleanest installation.
Feel free to call
ProdigyCustoms is offline
post #5 of 25 (permalink) Old Aug 19th, 10, 01:48 PM
Hey Frank, how about a set up for a 67 with an inline 6? Is there such a kit?
johnny mac 1967 is offline
post #6 of 25 (permalink) Old Aug 19th, 10, 03:14 PM Thread Starter
Andy
Feel free to call
Thank you for the information. I agree with you on the factory style vents. I definitely want to use those. I do have a long water pump.
I just purchased this alternator bracket setup, http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
and this power steering bracket setup, http://www.marchperf.com/instruction...structions.pdf I had to go with this because my block isn't drilled and tapped for a normal power steering bracket setup.
Does the kit come with a compressor bracket that will work for me? I thought it would be easier to post these links for you to see before I gave you a call. What are your business hours? I will try to call friday or monday.
post #7 of 25 (permalink) Old Aug 20th, 10, 03:09 AM
Joe
Andy,
Very nice engine, where did you get those valve covers from, I think they look sharp!
68, 396- 330 RWHP/ 354lbsTQ. TKO 600- 5 Speed. Ford 9in- 3.70 gear. Magnaflow 2 1/2 inch exhaust. --Semper Fi-Joe
Dirt's68 Camaro is offline
post #8 of 25 (permalink) Old Aug 20th, 10, 04:59 AM
Patrick
Try this.
http://www.blown.net/cars/camaro68/ac/index.html
I used some Spectre 3" air intake couplers for the back of the stock vents to put the hoses in. They worked great. Also Kwik brackets and compressor is half the cost of S&P this guy used initially.
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
68problemchild is offline
post #9 of 25 (permalink) Old Aug 20th, 10, 05:33 AM
Chris
130fe's Avatar
Thumbs up Re: Vintage Air Kit 67 Camaro
Here are some of my install- http://rides.webshots.com/album/560202775dZkBLK They are in my signature link (if that one doesn't open right). The kit installs pretty easy and uses the stock controls. As said before, buy it through Frank @ Prodigy Customs- one of our great sponsors! The great thing about using Frank is he can tailor the system for your particular needs, its like one stop shopping at a great price.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #10 of 25 (permalink) Old Aug 20th, 10, 09:59 AM
Frank
Yes we have a compressor bracket for you. I will need to know if your running a vee belt or serpentine, I am available until 6 oclock today.
Give me a call, we can talk through it much quicker
post #11 of 25 (permalink) Old Aug 20th, 10, 01:14 PM
Pictures of the Classic auto Air system are worth looking at.
http://www.classicautoair.com/?q=67_...ontiac_AC.html
^^ click and look ^^
Then click each thumbnail for a detailed pic.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #12 of 25 (permalink) Old Aug 20th, 10, 03:42 PM Thread Starter
Andy
V Belt. I will call you monday. I got tied up at work today and didn't get home late. I'll call you on my lunch break if I have to, lol.
post #13 of 25 (permalink) Old Aug 20th, 10, 05:33 PM
Terry
I installed Classic Auto Air in my '68. Was able to use the original factory R12 controls and vents. Been blowing very cold for 2 years.
IRON MAN is offline
post #14 of 25 (permalink) Old Aug 20th, 10, 05:49 PM
Frank
I will be in the shop all weekend putting my street racer back together. Call whenever.
post #15 of 25 (permalink) Old Aug 20th, 10, 08:58 PM Thread Starter
Andy
Originally Posted by Dirt's68 Camaro View Post
Andy,
Thanks. They are made by gm performance parts. I picked them up from jegs.
