69 Defroster Defuser - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 22nd, 10, 03:31 PM Thread Starter
After 41 years, its finally time to replace my Defroster Defuser. Problem is, I need to find one. Does anyone here have a WORKING defuser or know where one can be had. I AM willing to pay. Mine has gotten to the point that it is so warped that the flapper inside will not close or open fully anymore. This is NOT the Y shaped piece that runs from the defroster vents in the dash but the piece that sits UNDER that Y piece. My car does have a/c but I believe the defuser is the same in a/c and non a/c cars. My email is [email protected],net.
Thanks in advance
RAJ484 is offline
post #2 of 3 (permalink) Old Aug 22nd, 10, 04:59 PM
Andrew
Andrew69's Avatar
Re: 69 Defroster Defuser
Are you talking about the box that sits under the dash with the flapper doors to direct the air to the defroster or floor ducts? This is rebuildable with a new seal kit. If not possible to rebuild I see them on eBay occasionally and the restoration shops sell a reproduction unit. Also know that the same box was used in the Nova from about 1968 through about 1973. Where are you located?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 3 (permalink) Old Aug 22nd, 10, 09:31 PM
69z28freak's Avatar
Is this what you are looking for?
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
