New water pump squeals - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 23rd, 10, 06:56 PM Thread Starter
I just replaced the water pump on a 350 with a new Stewart phase 2 pump. The pump had been sitting on the shelf here for a year. I started up the motor and I thought it sounded a bit loud but not too bad. The cooling was fine--actually it was great. Maybe an hour of running time later I've developed a squeal at idle that goes away with increased RPM. Could the main bearing have dried out while sitting on the shelf? Do you think it might get better with use? Again, no leaks and superior cooling.
I checked the belts and they are fine--all new and tight.
Thanks.
sthoma10 is offline
post #2 of 6 (permalink) Old Aug 23rd, 10, 08:32 PM
Steps
Re: New water pump squeals
Did u check the belts by pouring a little water on them?
Use a mechanics stethoscope and probe around to locate the sound or a long screwdriver to your ear.
Could be several things including the impeller touching something inside
Doubt the main bearing they are sealed units.
Steptoe is offline
post #3 of 6 (permalink) Old Aug 24th, 10, 04:21 AM
Peter
If it is the belt, use a candle and place it against the belt while it is running, it should quite the belt down.
inntyme is offline
post #4 of 6 (permalink) Old Aug 30th, 10, 02:08 PM Thread Starter
Now I'm not so sure it is the pump--although the scraping/squeal comes from the front and it seems high rather than low in the bay. I tried water on the belts and no change. I also noted that the noise only starts when the engin is fully warm and the noise stops when you increase the RPMs. In addition to changing out the water pump I also changed the balancer and front seal--no problems with the install and no leaks.
sthoma10 is offline
post #5 of 6 (permalink) Old Aug 30th, 10, 03:57 PM
One drop of antifeeze on a belt or pulley and it will howl.. Try the candle wax or whatever. I squirt a little WD40 to test....
BPOS is offline
post #6 of 6 (permalink) Old Aug 30th, 10, 09:44 PM
Steps
Water lasts about 2 min
Candle wax about 5 /10 mins
Get a mechanics stethhoscope, they are only a few bucks and real handy, or us a long screw driver with the handle held to you ear, place around the engine till u find the sound.
Would not be suprised if the alternator bushes/bearings
Does it disapear when take a bit of tension off the beltsa
Steptoe is offline
