temp questions - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 26th, 10, 11:18 PM Thread Starter
wayne
temp questions
ok guys i have a 406 with 10.89 to 1 comp. timing set at 37.5 total. i have a three core ALUMINUM radiator, 106 thermostat with little hole for flow, stock sytle long water pump,and 16" electric fan.
the car ran at 190 all day. I changed the heads to afr and i moved the temp sensor to rear of the intake. now i run 210-225 all the time. is this normal? or what should i change?
wayne33 is offline
post #2 of 6 (permalink) Old Aug 27th, 10, 12:15 AM
Steiner
Re: temp questions
The back port on a lot of intakes is a deadhead with no flow. Also, did you set your timing number going by the dyno or some other means? Mine was set on the dyno and only needed 30 degrees with AFR heads and 10.11:1 compression. It runs 175 degrees going down the road with a 180 degree thermostat and rarely goes over 180 when sitting. This is with an ECT sensor in the front of the intake.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 6 (permalink) Old Aug 27th, 10, 12:37 AM Thread Starter
wayne
Re: temp questions
the timing was set with one of the new sytle timing lights.
wayne33 is offline
post #4 of 6 (permalink) Old Aug 27th, 10, 12:46 AM
Steiner
Re: temp questions
No, I mean how did you decide that 37.5 degrees was the best amount? AFR heads do not need as much timing as a stock or lower performance head. Even most tests I've seen with Vortecs usually run 32-34.
Since it's so easy to dial back your timing, try knocking it down to 30 to see how it runs and then you can add some back if it feels like it'll take it.
Also if that rear port does not have a crossover to the other side your sensor is in fairly stagnant water so it's most likely going to read high. Especially since it's on the back side of the engine.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 6 (permalink) Old Aug 27th, 10, 09:16 AM Thread Starter
wayne
Re: temp questions
Would it be smarter to put the sensor back in the side of the head? I will drop timing and see if that will help.
I plan to get it on DYNO soon. I just wanted to work out all bugs before.
wayne33 is offline
post #6 of 6 (permalink) Old Aug 29th, 10, 08:01 AM
Re: temp questions
The 16" thermo will move much less air compared to an OE 7 blade with clutch.
Often the thermo fan shrouds are very restrictive too.
Got pics?
BlackoutSteve is offline
