Heater blower motor repair? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 29th, 10, 07:39 AM Thread Starter
Guess
HwyStarJoe's Avatar
Question Heater blower motor repair?
Is it possible? I'm sure it's the bearings because it growls like a dog. I'd rather only take it off the firewall once. I don't want to remove it and find out I can't fix it myself.
If not, it goes on the Christmas list.
HwyStarJoe is offline
post #2 of 6 (permalink) Old Aug 29th, 10, 09:34 AM
Ashlee and Andy
Re: Heater blower motor repair?
when I bought my 68 the blower motor would growl all the time, no matter what. so I pulled her out of the car, replacement motor in hand. When I got the factory part out I looked at it, and wedged under the wheel was a single pebble, I grabbed a screw driver and wedged that rock out sprayed a little silicone spray on the shaft and hooked a battery up to it.
Motor didn't squak at all, went back in and still works fine
ap68 is offline
post #3 of 6 (permalink) Old Aug 29th, 10, 12:21 PM Thread Starter
Guess
HwyStarJoe's Avatar
Yeah... I wish it was that easy. I already had it apart... even bench tested with 12V. I must not have let it run long enough to growl when I tested it. Probably just wanted to make sure it worked.
I suppose it could be the cage wobbling. What a pain.
post #4 of 6 (permalink) Old Aug 29th, 10, 05:46 PM
The deciding factor is if the cage can be removed from the existing motor.
If it can, a replacement can be bought and replace it.
Otherwise, its a whole assembly.
You might be lucky and find a set of brushes and bushings at Ace Hardware store.
Everett#2390 is online now
post #5 of 6 (permalink) Old Aug 29th, 10, 09:20 PM
Dale
If it is the rear bushing you can drill a small hole in the end of rhe motor and squirt some oil in it.
Personally, I would just buy a new motor.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #6 of 6 (permalink) Old Aug 30th, 10, 08:49 AM Thread Starter
Guess
HwyStarJoe's Avatar
Right....
The cage definitely comes off. I has the whole assembly apart at one point.
Thanks... I'll look for a motor.
