69 Camaro will not cool with elec. fan?? - Team Camaro Tech
post #1 of 30 (permalink) Old Sep 1st, 10, 04:37 AM Thread Starter
So, I installed teh Vintage A/C in my 69 Camaro and kept the flex fan at first. It would keep it cool except on really ot days if I caught a few lights in a roll the temp would go up slowly but never hot and as soon as I drove a mile or so it would cool back down to normal. I installed a Jegs 16" elec 2300 CFM fan and removed the flex fan. It is worse now. I tried it with the factory fan shroud around the elec fan then no shroud doesn't seem to matter. It is running above normal and will not go back down even with a 8-10 mile run last night. The Radiator is fairly new stock one. Any ideas or just go back to the flex fan?
69 SS Silver Camro, LS3 efi, 4L60e with 2800 stall, mini tubed 12bolt 3.73, Ridetech front suspension ladder bar rear.
slugo10 is offline
post #2 of 30 (permalink) Old Sep 1st, 10, 05:23 AM
Ted
Re: 69 Camaro will not cool with elec. fan??
So what temps are you seeing? Over 200, 210, 220? What thermostat are you running? Maybe the fan isn't pulling enough CFM. Whether you are running the flex or the elec. fan you should be using a shroud. And properly positioned.
tgifford5 is offline
post #3 of 30 (permalink) Old Sep 1st, 10, 05:54 AM Thread Starter
It is getting at least 210-220 prob little higher. I have the stock Cold-Hot gauge but it is for sure getting hotter with the elec fan vs the flex. I had a 180 ther then put a 160 in with no change. I left the factory shroud on the rad then removed with no change on the elec fan. Would a new Alum Rad make a big difference?
slugo10 is offline
post #4 of 30 (permalink) Old Sep 1st, 10, 08:18 AM
Ted
I may be wrong on this but I think you should go with a higher degree thermostat. With the smaller one it is letting the coolant circulate more. Without allowing it to cool in the radiator. My 69 was an original A/C car and had the stock radiator. I believe they were all the 21"ers. I did not have a cooling issue and used a flex fan. I did not have gauges at that time, but it never overheated. I am now running the Entropy aluminum BB radiator with dual fans. But don't have my VA installed yet. My temps run in the 185-190* range tops. But again I am not running A/C at this time. Another question. Does the car run good? I have read that bad timing can cause the engine to run hotter.
post #5 of 30 (permalink) Old Sep 1st, 10, 08:41 AM
Dan
trackman's Avatar
I think the Jeg's fan is maybe putting out 1/2 to 2/3's of the advertised cfm. Buy a Spal or Derale. Their advertised cfm #'s are a little more believable.
67 RS convertible
Mark Jones 496...690hp
Liberty modified TKO600
Holley HP EFI
trackman is offline
post #6 of 30 (permalink) Old Sep 1st, 10, 08:46 AM
Circulating coolant is what cools the engine. Reducing the flow of coolant will make the engine run warmer.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #7 of 30 (permalink) Old Sep 1st, 10, 09:19 AM
Get a mark III or taurus fan. 4000 cfm or better
68 Camaro~LSx ~all motor
post #8 of 30 (permalink) Old Sep 1st, 10, 09:35 AM
Mickey
Moonpie's Avatar
May need a bigger radiator. 3 or 4 row if it isn't already.
Moonpie is offline
post #9 of 30 (permalink) Old Sep 1st, 10, 10:00 AM Thread Starter
I was trying to keep the radiator I have since it is fairly new and it stayed cool with flex fan setup. Maybe I will try to return the Jegs fan and get another brand. I sure do like how quiet the elec fan is so I would rather not use the flex fan permanently.
slugo10 is offline
post #10 of 30 (permalink) Old Sep 1st, 10, 10:48 AM
Larry
larryh56's Avatar
I have Vintage Air on my 68 with slightly hi-po 327 and new stock radiator. I am running a Flex-a-lite black magic x-treme electric fan and my car never over heats and I live in the SoCal desert. The shroud fits great and I like the look of the big, single fan. A good shroud is essential IMO with a/c. You also need to use a trinary switch that will start your fan whenever the a/c is on (no matter the outside temp). I would get rid of the flex fan ASAP - do a search if you would like a few reasons.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #11 of 30 (permalink) Old Sep 1st, 10, 11:09 AM Thread Starter
larry56 are you using the Flex-a-lite 180?
slugo10 is offline
post #12 of 30 (permalink) Old Sep 1st, 10, 01:25 PM
I have had issues as well. Big Block, Vintage Air flex fan. I changed to dual electric fans, no help. New big alum radiator, new water pump, timing all over the place. Still no help. I am now trying the right , short water pump with a clutch fan and the high po stock fan. I hope that helps me.
396 RS SS RED 1968 Just like when I was 18 only 10 times the price
dynaflash is offline
post #13 of 30 (permalink) Old Sep 1st, 10, 04:28 PM Thread Starter
So I removed the elec fan and put the flex fan and shroud back on with the new 160 thermo and it is running a 1/4 cooler than the elec fan did. WTH. All I was tryn to do with the elec fan was to ensure it didn't get hot for cruisin the coast next month in traffic. Guess I will look into a factory clutch and fan setup.
slugo10 is offline
post #14 of 30 (permalink) Old Sep 1st, 10, 04:35 PM
DT
Donny
DT's Avatar
Most electric fans are reversible, (Push/Pull) Double check the connections to make sure the air flow is correct! All you have to do is switch the power leads to reverse the motor. Positive becomes negative, and negative becomes positive.
DT is offline
post #15 of 30 (permalink) Old Sep 1st, 10, 05:33 PM Thread Starter
It was def pulling
slugo10 is offline
