getting hot on highway - Team Camaro Tech
post #1 of 54 (permalink) Old Sep 13th, 10, 05:15 AM Thread Starter
hey guys i have a 355sbc with m21 muncie and a 4.10 rear end.
it runs 180-190 all day long in the city and at idle it never gets above 190.
but after 5 minutes on the highway doing 70-80mph (3600-3800rpm) it creeps up to 230 and will go from 220-230 depending on my speed.
i have stock radiator with stock shroud with edelbrock high flow pump and NO thermostat; do you think it's time for an aluminum radiator? would that solve my highway issues?
m21man is offline
post #2 of 54 (permalink) Old Sep 13th, 10, 05:51 AM
Banned
Alan
98blackburb's Avatar
Re: getting hot on highway
I'm no expert but I have heard somtimes they run cooler with a thermostat because of pressure vs flow.....its a cheap try...Is it a 4 core radiator?....that gear is'nt helping though.
98blackburb is offline
post #3 of 54 (permalink) Old Sep 13th, 10, 08:34 AM
DjD
DjD's Avatar
What kind of fan are you running? Most flex type fans will flatten out at higher rpm and block air flow. Your symptoms sound like this could be the case...
You really should run a t-stat, if your cooling system is up to snuff it will regulate the coolant temps and keep your engine at a more consistent temp. It will also insure your engine gets up to operating temp quicker...
...Dennis
DjD is offline
post #4 of 54 (permalink) Old Sep 13th, 10, 10:49 AM
TJ
You need to put the thermostat in, im almost willing to bet that will fix it.
What happens is with your higher engine speed the coolant is flowing at a faster rate thru the radiator and not having time to cool down any, but at idle the coolant is circulating slow enough to lower the temp as it passes thru the radiator.
TJ
z28kid is offline
post #5 of 54 (permalink) Old Sep 13th, 10, 03:07 PM
Steps
If is not the fan or shroud..on the highway there is far more air than any fan can supply...hell it will run without them fine.
The issue is not so much no thermstat but rather lacking the measured restriction of the thermostat hole... do not get any old 180 from the spares shop, get the std GM speced on or the GM high flow speced for your engine.
Rates of opening , how much opens, the diam of the hole all vary as to the application they are for.
You have classic symtoms of no thermostat.
The other issue could be the bottom hose re enforcing ring inside has corroded and collapsed, which causes the bottom hose to suck in and partly restrict the coolant...good possibilty considering your final ratios.. highway cruise rpms.
The other issue could be the radiator need cleaning...not flushing, but cores manually cleaned..
Nope just routine maintance and set up like the factory intended....
The factory cooling system back then was WAY WAY over built for the application...hence why they run for yrs cores blocked up with no issues...till they get really blocked up.
you can spend a lot of money getting a Al radiator install etc, or get yours serviced at a fraction of the cost...its your money.
Steptoe is offline
post #6 of 54 (permalink) Old Sep 13th, 10, 04:08 PM
Is your stock radiator 2 or 3 core? If it's 2 core and hasn't been cleaned out in a while, it could be your problem.
Not to argue with others here, but I ran without a thermostat for many years in my moderately built 355 (11:1 compression with 5.xx gearing) and never ever had a hint of an overheating problem, but it's the cheapest thing to try so I would go for it first. Next I would suggest you might be running lean on your jetting which would show up in the RPM range you are talking perhaps. Next I wouild go after the radiator if you still have problems. Flush it good first (cheap) and if that doesn't work and you end up buying a radiator get an Aluminum one.
69 Pace Car and 69 Hard top
srode is offline
post #7 of 54 (permalink) Old Sep 13th, 10, 04:52 PM
Banned
Alan
Don't they even make washers that will restrict flow for radiators for this issue also?
post #8 of 54 (permalink) Old Sep 13th, 10, 04:57 PM
yea i dont believe it's the no thermostat issue.
if its a stock rad; i think it may be getting old.
12bolt is offline
post #9 of 54 (permalink) Old Sep 13th, 10, 05:46 PM
TJ
The device that removes the heat from your engine is a radiator, not a water cooler. You want the radiator to be as hot as you can get it to remove as much heat as possible, which means pumping as much mass through the radiator as possible. Any lowering of the outlet temperature will be accompanied by a raising of the inlet temperature in order to maintain the average radiator temperature required for heat balance.
The same physics applies to the air side, you want to pump as much cool air as possible through the radiator in order to maintain the highest temperature difference between the hot radiator and the cooling air.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #10 of 54 (permalink) Old Sep 13th, 10, 06:13 PM
bingo your exactly right onovakind67. engineering heat transfer
12bolt is offline
post #11 of 54 (permalink) Old Sep 13th, 10, 09:26 PM
TJ
Without a restriction slowing his coolant the cooling system is just a heat pump, if what your saying were true we wouldnt have any use for big multi core alum. radiators or the nice edelbrock water pumps.
Its plain and simple that without his coolant taking the time to transfer some of the heat when passing thru the radiator the system will not work properly.
TJ
z28kid is offline
post #12 of 54 (permalink) Old Sep 13th, 10, 11:18 PM
Steps
OH crap here we go again....never mind lol A thermosta is only a couple bucks he may as give it a go right?
I dont know, but Smokey Yunick did a lot of work on his dynos and on the track didnt run a thermostat, but did run a resticter than was not much different than the flow of a thermostat
And I had issue yrs ago well before internet....and it was not till reading yunick, I tried it...gess what?......I have never had an issue of heating in that time other than 1 water pump died and a few fan belts and hoses.
When the water goe thru too fast it comes out the other side warmer, therefore to pull the same amount of energy out of the motor it has still got to increase the same amount of degrees.
But hey a thermostat is cheap, 10 mins to install..what the hell.?
Steptoe is offline
post #13 of 54 (permalink) Old Sep 13th, 10, 11:48 PM
Banned
Alan
51105 - JEGS Water Restrictors
JEGS #555-51105
Water Restrictor Discs3/pkg
$7.99 Ships Today
Share |
Allows you to control the rate of heat absorption from the engine block and heat dissipation from the radiator in Race Only Applications. Used by professional engine builders to obtain optimal temperature control and maximum power. Kit contains 3 anodized discs with an I.D. of 5/8'', 3/4'' and 1''. Color coded for easy identification. Fits most AMC, Ford & GM V6, V8 engines with a 2-1/8'' O.D. thermostat.
post #14 of 54 (permalink) Old Sep 13th, 10, 11:50 PM
Banned
Alan
63440 - Moroso Water Outlet Restrictor Kit
Moroso #710-63440
Water Outlet Restrictor Kit, Chevy V8 and V6, Ford 260-302, 351W
$6.99 Ships Today
* Similar Items
* Add to Wish List
* Continue Shopping
Share |
The Moroso water outlet restrictor kit allows you to control the coolant flow leaving the engine. This lets you control the amount of heat that is absorbed by the coolant. The kit consists of three plates with 5/8'', 3/4'', and 1'' holes for optimum flow. All have a 2-1/8'' outside diameter and come in red, blue, and gold anodizedaluminu
post #15 of 54 (permalink) Old Sep 13th, 10, 11:51 PM
Banned
Alan
8229 - Weiand Water Flow Restrictors
Weiand #925-8229
$12.99 Ships Today
* Similar Items
* Add to Wish List
* Continue Shopping
Installation Instructions for 8229 - Weiand Water Flow Restrictors
Share |
Mounts under water neck on the intake manifold to restrict water flow for improved heat dissipation and cooling. Includes three plates (5/8'', 3/4'', 1''). Fits GM V8, V6 & SB-Fords.
