Aluminum Radiator/Dual elec fan combo help - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 13th, 10, 04:42 PM Thread Starter
hey guys. i dont want to spend too much money nothing over $800. what are your recommendations for alum radiator/elec fan combo that I can bolt on. I want to buy something high quality and be done with it.
I'm running a 350 small block with factory ac.
I'm thinking about this one. any other suggestions??? I
http://cgi.ebay.com/ebaymotors/Alumi...item3a5e94866f
12bolt is offline
post #2 of 11 (permalink) Old Sep 13th, 10, 05:20 PM
67 Camaros Rock
Joe Harrison's Avatar
Re: Aluminum Radiator/Dual elec fan combo help
A number of people have posted that they like that set up. Look on Amazon they sell there also. Watch out for the auto and manual versions they sell.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #3 of 11 (permalink) Old Sep 13th, 10, 05:38 PM
prostreet69camaro's Avatar
I would buy that one also. I have the Be Cool w/ dual spal 11" fans and it cost alot more than that.
prostreet69camaro is offline
post #4 of 11 (permalink) Old Sep 13th, 10, 05:41 PM
Bobby
i run the entropy, very good quality for the price. i did pick up the fan wiring harness from them also.
69 Camaro Z/28 Rally Sport 10A of 68. 50 S with 723 int. .040 over 302 with m22 autogear wide ratio. BU 12 bolt posi.
69CamaroRT is offline
post #5 of 11 (permalink) Old Sep 14th, 10, 02:57 AM
If you ask me, that shroud is restricting a 23"X17" (391 sq/in) core down to a 2 x 12" diameter (226 sq/in) of air flow at highway speed.
391" in and 226" out with fan blades in the way can't be good.
BlackoutSteve is offline
post #6 of 11 (permalink) Old Sep 19th, 10, 08:16 PM
Steven
I just put an entropy on my 69 (427 big block). Works awesome, never goes over 190. Hits 180 the fans kick on. They shut down when the temp drops. Works perfect. The wiring harness is a bit bulky but i mounted it on the fender near the battery.
ssenay72 is offline
post #7 of 11 (permalink) Old Sep 20th, 10, 02:32 AM
Why do you want an electric fan? I can see it if you have a specific need for clearance, desired appearance, or control / ECM reaons but not for optimal cooling. I find it hard to believe a guy can beat a factory shroud / 7 blade fan with an Aluminum radiator for cooling. Like Steve said above, those shrouds look restrictive. I went with an Alumitech 23 inch radiator and stayed with a factory shroud (from a 68 AC car) and fan for mine. The Alumitech ends look just like the factory Harrison radiators except they don't have the embossment and the core is obviously different.
On Edit: I think I paid 540 shipped for mine
69 Pace Car and 69 Hard top
srode is offline
post #8 of 11 (permalink) Old Sep 20th, 10, 04:47 AM
Bruce
I am running a stock 4 core with a 7 blade fan with a factory shroud on 3 of my BB cars.
They are all over 400HP with AC and none of them have a heating issue, on my 69 truck I tow the show cars and no overheating for half the price of going with aluminum and electric fans. I have them detailed with gloss color to match the engine compartment, even the shroud and they look great.
The Camaro Guy is offline
post #9 of 11 (permalink) Old Sep 20th, 10, 06:06 AM
Michael
Factory shroud w/ 7 blade fan and clutch work so well, they even somehow managed to cool AC cars (BB, SB and 6 bangers) with the old style brass radiators back in the day.
Imagine how well they work with just a modern aluminum radiator today.
Nobody has trouble (complains) with the factory shroud and fan setup. The only setups you see people whining about are electric fan cooled and usually after spending loads of money and a lot of head scratching.
Save your scalp and wallet, use the factory setup.
mahunt is offline
post #10 of 11 (permalink) Old Sep 20th, 10, 07:29 AM
67 455 Bird ragtop's Avatar
For a cheap dual fan set up alot of my 1st gen friends use a dual fan setup from a 4th gen LT1. Pretty cheap from a yard. Fit a 1st gen radiatior prety well also. Some just use a good set of relays and no controller. Others use a good controller setup.
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
67 455 Bird ragtop is offline
post #11 of 11 (permalink) Old Sep 20th, 10, 09:52 AM
Ted
I run the Entropy on my 69 also. Very nice and I also used the wiring harness. I did splice and resolder the wiring as the harness was rather large. My temps run the same as Steven. I am running a 350 w/AC. If you get the radiator with the built in tranny cooler you can always plug the holes if you have a manual tranny.
tgifford5 is offline
