Dual 1.25" or 1.5" alum. cores? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 14th, 10, 05:50 PM Thread Starter
Tom P's Avatar
Question for high HP cars using the factory 7-blade clutch fan and factory shroud - whats the thickness of your radiator cores? Dual 1", 1.25" or 1.5"??
Looking to cool BBC 625 HP range.
I've narrowed it down to Don with Alumitech who can whip up a dual 1.25" core and still use the standard 3" side tanks. Also Griffin has both a dual 1.25" or dual 1.50".
Clearance is tight with the long WP w/clutch fan - any recommendations?
Tom P is offline
post #2 of 5 (permalink) Old Sep 15th, 10, 01:16 AM
Re: Dual 1.25" or 1.5" alum. cores?
I have a 5 core copper/brass that is 3.5" thick and yes, clearance is tight. There is a tad less than 1/2" between the clutch and core which means I have to remove the fan to swap a belt if need be.
So, I think with a 2.5" or 3" core, you will be fine with near an inch clearance.
Also, due to the design of alum core's much larger tubes, the 3" would be about the same capacity as my 3.5".
That is why people think alum cools better than copper. It doesn't. Heat exchange is almost identical between the two materials.
it's because alum cores are more compact for the same given capacity, so a thinner alum core appears to cool as good as a thicker copper/brass..
More capacity is always better so I'd go the 3". I doubt it will be an issue in traffic when the fan has to pull air through it either. My 7 blade clutch pulls air through my core just fine and the temp has always been 5-10°F above the 180° thermostat. (454, 12:1 & 522 rwhp)
BlackoutSteve is offline
post #3 of 5 (permalink) Old Sep 15th, 10, 01:36 PM Thread Starter
Tom P's Avatar
Thanks Steve! I don't mind removing the clutch fan to swap a belt - minor compared to the increased cooling benefits.
Tom P is offline
post #4 of 5 (permalink) Old Sep 16th, 10, 12:11 AM
..and with a 3" core, hopefully you wont have to.
post #5 of 5 (permalink) Old Sep 16th, 10, 04:37 AM
Bruce
x2 with Steve. I have the same set up with NO heating problems.
The Camaro Guy is offline
