No Clearance - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 18th, 10, 05:13 AM Thread Starter
Bruce
No Clearance
Got everything put together and the front cap aligned on the 69. Now the top stainless hose on a curved neck chrome adapter is touching the double pulley on the Vintage Air compressor. Mounted on the drivers side. BB engine with a 4 core original radiator. Any ideas to get some sort of clearance? VA say they do not have a single pulley, which would solve the problem. Hoses are cut to the compressor so a longer belt would create another issue!
The Camaro Guy is offline
post #2 of 7 (permalink) Old Sep 18th, 10, 06:53 AM
Re: No Clearance
Got a pic?
Does your OE radiator have a curved neck? BBs with A/C had a curved neck and also used a different hose (often listed as a "COPO hose" ), all to clear the A/C compressor.
Like this..
BlackoutSteve is offline
post #3 of 7 (permalink) Old Sep 19th, 10, 06:40 AM Thread Starter
Bruce
Re: No Clearance
It is not a curved neck radiator. I used a curve neck chrome adapter on a ribbed stainless steel hose. That is one solution is to change to a curved tube from the radiator. It would be a chore at this point but eveything is when you build a custom engine compartment. I could also modify the brackets to pull it closer to the firewall. I see your belt appears to be a bit off center to the back.
post #4 of 7 (permalink) Old Sep 19th, 10, 12:49 PM
Re: No Clearance
Could just be how it appears in the pic's point of view or "parralex error".. It's not my engine, but a pic I souced as an example.
post #5 of 7 (permalink) Old Sep 19th, 10, 01:27 PM
prostreet69camaro's Avatar
Re: No Clearance
You might try one of the aluminum billet thermostat housing that swivel. Billet Specialities makes one and you can turn it to move the hose away from the pulley.
http://cgi.ebay.com/ebaymotors/Polis...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Alumi...Q5fAccessories
prostreet69camaro is offline
post #6 of 7 (permalink) Old Sep 19th, 10, 01:46 PM
mark
mark x22's Avatar
Re: No Clearance
The belt is straight its the view at an angle with the compressor pulley above and behind the power steering belt it just looks angled. its my car .
mark x22 is offline
post #7 of 7 (permalink) Old Sep 20th, 10, 01:21 AM
Re: No Clearance
Thanks Mark.. It came up on a Google image search. Great example!
