69 Fan in a 68? - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 10th, 10, 05:13 PM Thread Starter
Chris
69 Fan in a 68?
Hi all:
I just installed a new engine (Blueprint 355) in my 68 RS. It has a long water pump. I am looking to put a new fan and clutch on. I was looking at Ground Up's website and saw that the 67-68 fan and clutch is for the short water pump. The 69-72 fan and clutch is for the long water pump.
Would there be any issues in putting the 69-72 setup in my 68? I didn't think there would be, but I wanted to check here first. I have been known to order parts that I thought would work, only to find out that they won't
Thanks for the help.
- Chris
68RS Project - taking much longer than expected
FFRiccio is offline
post #2 of 4 (permalink) Old Nov 10th, 10, 09:44 PM
Re: 69 Fan in a 68?
The clutch hubs were different part numbers between short and long pump applications and the fans were also different, but only with 67-68 being 5 blade and 69 & later being 7 blade.
I'd be also guessing the 69 & later fan & clutch would be best for you.
BlackoutSteve is offline
post #3 of 4 (permalink) Old Nov 11th, 10, 05:31 AM
Michael
Re: 69 Fan in a 68?
I have the '69 fan/clutch/shroud setup in my '67 w/AC and it works great.
mahunt is offline
post #4 of 4 (permalink) Old Nov 11th, 10, 06:44 AM Thread Starter
Chris
Re: 69 Fan in a 68?
Thank you both for your help. I'll get the 69 setup.
FFRiccio is offline
