Heater box replacement - Team Camaro Tech
post #1 of 17 (permalink) Old Nov 11th, 10, 05:17 PM Thread Starter
Ralph
I have a 1969 Camaro that was orginally a small block car, it now has a 502. The heater box was not changed when the engine was installed. I would like to replace the heater box on the firewall to the big block style. The question I have is can I get the old heater box off and the new one on without removing the passingers side finder and inner finder ??
Part 2. Do I have to change or modify the heater on the inside of the car when I do this since the heater core will be in a differance place. Classic Muscle sell a BB heater box coversion kits to do this with.
loveoldchevys is offline
post #2 of 17 (permalink) Old Nov 11th, 10, 07:09 PM
Camarodude67
Re: Heater box replacement
Just do a search, this has been answered 20 times before. You do not have to remove the fender, there are detailed pics on how to get this done.
I converted my 69 Ragtop from 350 to Big Block and left the heater core alone, because it is a pain. Luckily for me it was a low mileage car and had a good core.
Jeff G.
69 Vert Triple Black
69 Vert LM1 RS
69 Vert SS Hugger Orange
http://community.webshots.com/user/jeff69rag2001
camarodude67 is offline
post #3 of 17 (permalink) Old Nov 12th, 10, 07:51 AM Thread Starter
Ralph
I have considered replacing the SB heater core and just using it. The one that is in it now leaks. The Hoses coming out of the heater core would be close to the Valve covers on the 502. But It would work. I really do not want to remove the finder on the car and take a chance of scratching it.
post #4 of 17 (permalink) Old Nov 12th, 10, 09:44 AM
I think if you want to remove the box that's under the hood you have to remove the fender - UNLESS - you have really skinny arms with 3 elbows, or are willing to cut an access hole in the inner fender.
What's easier is to convert your existing box to a big block style, and you can do it in place. Do a search. There is a part you have to buy and you have to drill a couple of holes and plug off the SB core tube holes.
https://www.camaros.net/forums/showth...ore#post742760
BPOS is offline
post #5 of 17 (permalink) Old Nov 12th, 10, 01:51 PM
Yes, as Al said, it is easy to convert the box without removing the firewall side cover. The repro BBC cover is not a good piece anyway, much thinner gage than OE. All you need are the measurements, a correctly sized hole saw, and the reinforcing plate and gasket.
Eric
Eric Kammerer is offline
post #6 of 17 (permalink) Old Nov 14th, 10, 11:45 AM Thread Starter
Ralph
Can you attach a link to where I can get the measurement to drill the holes in the existing SB heater box and convert it to a BB heater core. It looks like it would be pretty close if I put the reinforcing plate just to the right of the V indention in the Heater box and marked the center of the holes. ???????
post #7 of 17 (permalink) Old Nov 14th, 10, 12:01 PM
69z28freak's Avatar
Haha too funny Al. I am swapping out my inner because someone along the way cut hole in the inner to access the heater motor. Then they never ever welded a patch on the inner. Caused a lot of trouble with rust. I say stay away from cutting a hole in the inner and go the suggested route. You will be much happier in the long run. The fender is a bit of a pain to remove I found. I had to take most of the front end off to get mine off properly. The inner and out kind of wrap around each other. Plus you have to be very careful when removing not to scratch your srrounding paint. I also snapped off quite a few bolt heads in the process, which is also a pain. If you car is original and those bolts have never come out, you need to check out Martin Sr.'s post on rusty bolt extraction. It will save you a ton of problems. Wish I had seen it a few weeks earlier.
Good luck.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #8 of 17 (permalink) Old Nov 14th, 10, 12:40 PM Thread Starter
Ralph
When I did the search for 742760 , I could not access it. Will I have to update my membership to have access to old files?
post #9 of 17 (permalink) Old Nov 14th, 10, 06:07 PM
Banned
Bethanne
Nashville Beth's Avatar
Mike and Al both posted the link. Just click on it !!
Nashville Beth is offline
post #10 of 17 (permalink) Old Nov 14th, 10, 08:50 PM
Silvio
Let me know if you will go with a big block heater box. I'm in need of a small block heater box if you decide to replace it.
1968guppy is offline
post #11 of 17 (permalink) Old Nov 15th, 10, 11:54 AM
Fred
The great first gen mystery: Why didn't GM use the BB box in all Camaro's?
128.79mph 1.428 60'
Fred Ficarra is offline
post #12 of 17 (permalink) Old Nov 15th, 10, 01:18 PM
I've wondered that myself. Even with a small block it's still a crappy setup.
BPOS is offline
post #13 of 17 (permalink) Old Nov 15th, 10, 01:51 PM
Andrew
Andrew69's Avatar
Why oh why????
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #14 of 17 (permalink) Old Nov 22nd, 10, 05:01 PM Thread Starter
Ralph
Project is complete, I took the measurements off another BIg Block Camaro and used the small block blower duct on mine. I took a 1" metal hole saw and cut the holes . Installed the BB heater core in the heater and reinstalled the heater. The holes aligned perfectly. Purchashed the BB core tube support and seal. Works gerat and looks just like the factory.
post #15 of 17 (permalink) Old Nov 22nd, 10, 05:31 PM
You're welcome.
BPOS is offline
