Radiator shroud confusion - Team Camaro Tech
post #1 of 17 (permalink) Old Nov 21st, 10, 03:06 PM Thread Starter
I was going to order a new radiator and shroud and after doing some research the confusion began so help is needed. I have a 67rs with a/c currently it has a 21'' 4 core and matching shroud over the winter I was dropping in my new 406 at aprox 500hp so my question is;
Do 67 a/c cars have 21 or 23 cores?
Are big block 23'' core radiators different than 32'' small blocks?
When they advertise a shroud as 21'' is that the match to the core size?
I have holes and grommets in place for a 23'' core is that factory?
Will going with a 23'' 3 core vs a 21'' 4 core provide more cooling?
When buying a shroud with a/c they all seem to be for 23" cores
I would like to stick with a stock look but also do need performance out of this new combo that I am ready to buy.
ML67
post #2 of 17 (permalink) Old Nov 21st, 10, 04:16 PM
Bryon
bcm66's Avatar
Re: Radiator shroud confusion
Lots of information at this link that will probably answer most of your questions.
http://www.camaros.org/coolingsystems.shtml
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #3 of 17 (permalink) Old Nov 21st, 10, 04:25 PM
The way I understand it a small block with A/C got a 23 " 3 core radiator. My 67 with a 406 runs a 23" 4 core big block radiator with a small block A/C shroud. I'm also running a 7 blade high pitch flex fan, since I lost my old radiator due to a fan clutch failure. http://www.flex-a-lite.com/auto/html/7-blade-flex.html A good fan clutch with a proper fan might be better but this fan works great.
markw is offline
post #4 of 17 (permalink) Old Nov 21st, 10, 04:50 PM
Keith
The '67 A/C cars got a 23" 3 core radiator. Like markw, I run a 4 core big block (23"), but use a small block (w/ AC shroud), even though I do not have AC.
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #5 of 17 (permalink) Old Nov 21st, 10, 05:20 PM
Same here in my 69 pacer car with 408SBC
69 Pace Car and 69 Hard top
srode is offline
post #6 of 17 (permalink) Old Nov 22nd, 10, 02:41 AM Thread Starter
Ok, 23'' core sb a/c shroud seems to be a good combo but is there a difference between a bb and a sb 23'' core radiator? height? anything? + do you remember where you had bought the radiator and shroud from?
ML67
post #7 of 17 (permalink) Old Nov 22nd, 10, 02:58 AM
Got my radiator from alumitech - looks just like the OE except for the Harrison embossment missing. SB AC and BB are the same radiator from them. This one is for an automatic, but you can get a manual transmission one too.
https://secure.wf-api.com/www.alumit...big-block.html
srode is offline
post #8 of 17 (permalink) Old Nov 22nd, 10, 02:31 PM Thread Starter
Thanks guys I'm going shopping
ML67
post #9 of 17 (permalink) Old Nov 22nd, 10, 03:38 PM
The big block is not centered in the engine bay like a small block is, so the fan opening in the big block shroud is not correct for a small block. That's why you use a small block A/C shroud. It's 23" wide like the big block radiator but the fan opening is centered for a small block. I got mine here...http://www.rickscamaros.com/camaro-f...1967-1968.html http://www.rickscamaros.com/camaro-r...1967-1969.html The radiator was only $239.00 when I got it.
markw is offline
post #10 of 17 (permalink) Old Nov 22nd, 10, 06:04 PM
Keith
I got my raditor several years ago on ebay from Tamraz for under $300.00...I don't know if they still carry them--it was for an auto (but the manual was available at the time, too).
The shroud came from Year One, I think...
Also, for a big block ,not only is the Offset incorrect, it is too "shallow" for a small block--the fan won't quite reach into teh shroud the way it should....
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #11 of 17 (permalink) Old Nov 23rd, 10, 06:12 AM
For the offset and deep shroud with 4 row core radiator, I use the "814" shroud. I think this is offered in OEM and repro version. I use this on a 69 sbc car with 7 blade fan and gm delco clutch.
TC # 349
zdld17 is offline
post #12 of 17 (permalink) Old Dec 6th, 10, 05:48 PM
Big daddy
I too am confused,I have a 67 that is setup like a 69 alt on right,long wp,direct fit summit rad.Should I get a shroud for a 69?I also added va,this summer.Did they make a shroud for 69 a/c cars?If I get one for a 67-68 will the fan sit right?
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #13 of 17 (permalink) Old Dec 6th, 10, 07:53 PM
Yes - get a shroud for a '69 since you have a '69 accessory drive. Summit sells a bracket kit to attach the shroud at the bottom. http://www.summitracing.com/parts/SUM-380660/
BPOS is offline
post #14 of 17 (permalink) Old Dec 6th, 10, 08:08 PM
Big daddy
So,gm only made one shroud for 69 sbc a/c or not?
carhodge is offline
post #15 of 17 (permalink) Old Dec 7th, 10, 02:53 AM
Yep, only one shroud for a 69 SBC, AC or not.
srode is offline
