fan wont blow in vent position only - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 24th, 10, 09:46 AM Thread Starter
Hi all. I have a 1969 camaro with factory a/c. Everything works with control levers except in the vent position the fan wont blow air. When I put levor into a/c position fan kicks on and blows cold. defroster works as well as the heater. Thanks
sjh69camaro is offline
post #2 of 11 (permalink) Old Nov 24th, 10, 12:36 PM
Re: fan wont blow in vent position only
I assume that the a/c's fan will only work when the fan is switched on using the horizontal fan switch on your heater-a/c control.
"Vent", I thought, simply relied on the vehicle moving through the air and allowing outside air to enter via the cowl, just like the regular Astro Ventilation does.
Are you saying that the fan won't switch on unless the control is switched to heat or a/c?
BlackoutSteve is offline
post #3 of 11 (permalink) Old Nov 25th, 10, 08:38 AM Thread Starter
Yes that's correct. When I put levor in a/c position the fan turns on at any speed. Heater as well as defroster. Put the levor on the vent position the fan shuts off. All new switches except for the one on the heater box.Thanks guys.
post #4 of 11 (permalink) Old Nov 25th, 10, 01:37 PM
Do you have the middle lever with-in the "Bi-Level" range when trying to operate the fan?
post #5 of 11 (permalink) Old Nov 25th, 10, 09:32 PM Thread Starter
yep tried that the a/c pump goes on when i put on vent and the blower fan works on all speeds. For some reason it keeps on turning the a/c pump on in vent or bi-level. Once put on heater, hot, then defrost fan works fine and a/c does shut off.
post #6 of 11 (permalink) Old Nov 26th, 10, 07:56 AM
click's Avatar
Your package inside the dash looks like this:
When in 'vent' position the fan should work in all speeds. Something isnt right. Time to pull the unit out and go Thru it, clean everything up, maybe replace both the fan speed switch and the a/c switch which is what is showing in this photo. Ive not come across this issue before but with just 2 switches in play, if they have never been replaced, its time. I replaced mine, works great.
click is offline
post #7 of 11 (permalink) Old Nov 27th, 10, 05:25 PM Thread Starter
I have replaced all switches, cables. A/c still goes on in vent position. I disconneted the green wire to the A/C pump nad the fan does go on still. Looks like I have situation the the A/C pump is hot when I go to vent, A/C, and stays on at bi-level setting. The rest system works great. Put in hot and A/C the A/C pump stays on. Put in hot, heater and or defrost A/C pump shuts off. I think maybe the Diverter switch is bad. Thats the only one haven't replaced. Looks like A/C Green wire is getting power most of the time. Scott
Her
post #8 of 11 (permalink) Old Nov 28th, 10, 08:24 AM
click's Avatar
if green wire is hot all the time, then yes there is an issue with that diverter switch.
click is offline
post #9 of 11 (permalink) Old Nov 28th, 10, 09:00 AM Thread Starter
Were can I get a new switch couldn't find one. Or should clean inside of switch or get rebuilt. Thanks
post #10 of 11 (permalink) Old Nov 28th, 10, 03:13 PM
http://www.heartbeatcity.com/store/p...itch-w-AC--69/
http://www.heartbeatcity.com/store/p...witch--AC--69/
post #11 of 11 (permalink) Old Dec 1st, 10, 09:09 PM Thread Starter
Thans for all the information. I'll start looking thanks guys.
