396 Operating Temperature - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 2nd, 10, 06:10 PM Thread Starter
Does anyone know what the correct operating temperature is for a 396?
nghtrn99 is offline
post #2 of 6 (permalink) Old Dec 2nd, 10, 08:53 PM
Steps
Re: 396 Operating Temperature
GM says a 180 deg thermostat...and make sure it IS a GM for your engine, not any old 180 thermostat off the shelf at the store.
If the radiator is in good condition, shroud clutch all good...and these should be treated like a oil pump is when an enhine is rebuilt....manually clean and or replaced....the only time it will get around 190 is if tuned at sea level then get above the snow line.
Steptoe is offline
post #3 of 6 (permalink) Old Dec 2nd, 10, 09:18 PM
GM called for a 195 degree thermostat for the 396.
EricE
68 Butternut Yellow
SS Coupe 396/325
stope4 is offline
post #4 of 6 (permalink) Old Dec 3rd, 10, 04:33 AM Thread Starter
I've got a 2.5" dual core aluminum radiator, dual 13 inch 2500 cfm electric fans, and a Flex-a-lite Variable Speed Control Module for the fans. I can set the fans to maintain any temperature I want. Currently my thermostat is a 160 and I can maintain 160 even with the AC running full blast. I'll replace it with a 195 i guess and go from there.
nghtrn99 is offline
post #5 of 6 (permalink) Old Dec 3rd, 10, 12:08 PM
Steps
Not according to Themost manfactures spec manuals here, and my manuals include Glens manual dated 1974...They do show several engines do run 195 for late model chevs...which I believe has something to do with emissions...like ported vac dizzys after about 72 or 74.
Steptoe is offline
post #6 of 6 (permalink) Old Dec 3rd, 10, 12:21 PM
1968 Owner's Manual and Motors Manual, 1974 & 1969, all state 195°F.
I had to check for myself just to be sure.
