Entropy Radiator Install - Team Camaro Tech
post #1 of 13 (permalink) Old Dec 11th, 10, 12:07 PM Thread Starter
Finally got around to installing my new radiator from Entropy Radiator, one of your sponsors here.
Had a factory style 4 row core 23" radiator (no tag) that began leaking at one tube so rather than dump $$ in old school stuff, I went for the direct replacement aluminum 23'' two row, 1" tube design. Not a fan a bling but the dull aluminum is about as good as its going to get. I even considered having the thing anodized black.
Just as Tony from Entropy told me it would fall into place and it did even with factory off set style "814" fan shroud.
Now , its almost winter here and now way to see what temps will be like. I presume it would have to be at least what my old radiator did which was usually 100 above any ambient temp.
Well it shouldn't be too long before PowerTour 2011 starts.
Yes, I know the shroud retainer is not position correct, but it fits the shroud grove better.
ID:	19293   Click image for larger version
ID:	19294   Click image for larger version
TC # 349
zdld17 is offline
post #2 of 13 (permalink) Old Dec 11th, 10, 12:46 PM
Re: Entropy Radiator Install
I just installed their LS1/dual fan setup. I got a new core support as well, but the mounting holes only lined up on one side. The passenger side fit fine- the side with the nuts welded to the core. The driver side did not line up. I could get bolts thru the hole openings, but the rad was on a slant & the high side was above the top edge of the core support. I just drilled new holes. Had to grind one corner of the mounting tab on the rad just slightly to clear the bottom of the core support. No big deal, just wasnt expecting that. Pretty much been that way with my build the whole way...
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #3 of 13 (permalink) Old Dec 13th, 10, 12:41 PM
Scott,
Do you have one of the Chinese repo core supports? I know it's hard to tell where they come from, but a tip off is the steel is much thinner on the Chinese knock offs.
My jig for putting the brackets on is an original 69 big block core support. We bolt the brackets to the core support, space the back of the core 1/2" over the lip in the core support opening and tack weld the brackets into place.
entropyrad is offline
post #4 of 13 (permalink) Old Dec 13th, 10, 12:51 PM
Larry
larryh56's Avatar
Don, could you paint the top and tanks black?
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #5 of 13 (permalink) Old Dec 13th, 10, 01:10 PM
A little VHT black should do you fine (with proper prep) or maybe even BBQ grill flat black if you like ?
68 Camaro~LSx ~all motor
post #6 of 13 (permalink) Old Dec 14th, 10, 06:43 AM Thread Starter
I will probably slip some type of rubber or hard plastic in there to form a seal around the little gap that is normally there. That will cover the top shiny stuff. I am not a bling person.
TC # 349
zdld17 is offline
post #7 of 13 (permalink) Old Dec 20th, 10, 08:33 AM
Rich
Don that Radiator looks nice buy why go BB size instead of SB? that thing will never get hot!
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #8 of 13 (permalink) Old Dec 20th, 10, 09:41 AM
WES
I powder coated the top and side of my rad with black crinkle...looks just like plastic blends right in. Wes
WES 1967 yenko clone is offline
post #9 of 13 (permalink) Old Apr 19th, 11, 04:33 AM
Rob
satz28's Avatar
My new Entropy radiator is being delivered today and am anxious to install it. Took aprox 2 weeks from the time I ordered it to the UPS notification.
Got to get the tranny back in 1st - Needed to install clutch as the old stock clutch came apart late last year after 6-7 years and aprox 30 passes at the strip.
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/[email protected] 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is offline
post #10 of 13 (permalink) Old Apr 19th, 11, 06:21 PM
Rob
satz28's Avatar
Received the new radiator and looks as nice a advertised.
Rob
475 HP, 495# tor
satz28 is offline
post #11 of 13 (permalink) Old Apr 20th, 11, 06:41 AM Thread Starter
I know this is an old question but actually had the option of going to a 23'' 4 row long ago when my stock 19'' radiator started leaking. Then my stock 23" began tube leaks 3 years ago so I figured , why spend $125 to clean and reseal when for a few $$ more I could install a modern two row wide tube aluminum core.
Temps will run about 100 above any ambient temp, I do have to slip a piece of cardboard over half to keep temps up , when I am out in 40-50 weather running a 170 stat.
I can enjoy running the AC in town traffic with no issues.
TC # 349
zdld17 is offline
post #12 of 13 (permalink) Old Apr 20th, 11, 05:21 PM
If that 170 stat is working you should not need to cover the radiator, the stat should close and keep the temp up.
Seems like you might need a new stat or one with less holes drilled in it...
400bird is offline
post #13 of 13 (permalink) Old Apr 21st, 11, 05:22 AM Thread Starter
Yes, drilled, plumbed rear intake just below stat.
TC # 349
zdld17 is offline
