adding air to z28 - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 29th, 10, 07:26 PM Thread Starter
robert
adding air to z28
I am working on the 69 z28 now thinking about how to add air conditioning , but hide every thing as much as possible. has anyone mounted a compressor down near the botttom of engine were a power steering pump would be, or on passanger side down low.
rherring is offline
post #2 of 5 (permalink) Old Dec 30th, 10, 12:05 AM
parkbrau's Avatar
Re: adding air to z28
Hmmm. Will the compressor handle those RPMs? I have never seen a compressor hung that low.
parkbrau is offline
post #3 of 5 (permalink) Old Dec 30th, 10, 01:29 AM
I have a Sanden 508 on mine that is protected by an MSD RPM switch. When the engine RPM gets to about 5K (or whatever chip I choose to install), power to the compressor is cut and it de-clutches.
The Vintage Air kit I have also uses a high/low pressure switch which I am told should (should!) also pretect the compressor from excessive RPM as the pressure will raise with RPM and also cut power.
Had a mate years ago who damaged his old A6 from over-revving.
BlackoutSteve is offline
post #4 of 5 (permalink) Old Dec 30th, 10, 08:03 PM
john
wagonman's Avatar
If it is a real Z i would think twice about adding air.......
Is the car modified to such an extent that originality is out of the picture ever again?
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #5 of 5 (permalink) Old Dec 30th, 10, 08:24 PM
I'm completely with you on the modifcation thing, but having fitted a Vintage Air kit, if you pay attention to detail and thoroughly think through the install, you can get away without modifying any original parts and have it as a complete bolt in.
Use the OE heater cover or buy used GM to put a few holes in.
Buy a repro a/c dash pad instead of cutting the OE.. That sort of thing.
You'd be mad to modify an original Z.
