electric fans and a/c relays - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 30th, 10, 06:20 AM Thread Starter
Edm
Ed
There are so many out there and I am not sure where to start. I am installing new pulleys now and would like to change the fan/clutch out for an electric fan. I have a/c and would like to know what fan and relays would suit me best without overspending.
The Summit racing fan/shroud combo looked decent but I have absolutely no experience wiring electric fans to work with a/c systems. I mostly drive around town and use the a/c on a regular basis. I have a stock ZZ4 but I will be changing the cam this year. Any suggestions or recommendations will be greatly appreciated.
Edm is offline
post #2 of 3 (permalink) Old Dec 30th, 10, 10:42 AM
Re: electric fans and a/c relays
The horror.
BPOS is offline
post #3 of 3 (permalink) Old Dec 30th, 10, 12:16 PM
Larry
larryh56's Avatar
Originally Posted by BPOS View Post
The horror.
LOL, Al.
I have the older version of this fan: http://www.summitracing.com/parts/FLX-188/
It works great here in the desert. I looked for a while on eBay and found it substantially cheaper. IMO the best way to hook it up is using a spal 195 or 180 threaded temp sensor (also available on eBay or parts houses) and a couple of relays and switch at or under the dash. You can buy relay kits from http://www.madelectrical.com/catalog/rly-1.shtml that explain exactly how to wire it up and its all good quality stuff. If you have not already done it you may want to upgrade to a higher output alternator to run the electric fan.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
