Vintage Air Question - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 10th, 11, 09:26 AM Thread Starter
prostreet69camaro's Avatar
I am installing the Gen 4 kit in a 69 camaro. The last one I did I put the bulkhead in the firewall behind the fender.
Frank @ Prodigy recommends using a rubber grommet for the hoses to pass thru which would eleminate any leaks at the fittings on the 4 way bulkhead. It would be a continuous hose from the unit inside to the engine compartment. We have left a message with Frank but he has not retuned our call.
I am looking for the rubber grommet. Does anyone know the part number? Where do you get it?
I am assuming it would go in the old blower motor hole. I see on Vintage Air website they sell the plug for the firewall but not the grommet.
prostreet69camaro is offline
post #2 of 5 (permalink) Old Jan 10th, 11, 10:43 AM Thread Starter
Re: Vintage Air Question
Ok I called Vintage Air. The plate kit is from a 64-67 Chevelle kit. You have to buy the parts individually.
You will need these parts.
1- Plate- 62566-VCE
1- Bracket- 64164- VCB
4- Rubber Grommets- 33137-VUI
I figured I would supply the part numbers incase someone else does it like this.
post #3 of 5 (permalink) Old Jan 10th, 11, 05:19 PM
Frank told me just to use rubber grommets from the hardware store. Makes sense.
68 coupe ,572,tko
Denvervet is offline
post #4 of 5 (permalink) Old Jan 10th, 11, 07:08 PM
Dave C
This may be the issue I have with my air.But I dont like to use it anyway....
PRO.ST69orange
post #5 of 5 (permalink) Old Jan 11th, 11, 03:32 AM Thread Starter
This is true if you have already smoothed the firewall. If you still have the blower hole then the above kit goes in that hole.
