Installing a 12 volt solenoid valve - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 6th, 11, 07:26 AM Thread Starter
68Camaro68's Avatar
I seen this done a few times on several cars. The owner installed a 12 volt solenoid valve in line with the input to the heater core. It was installed on the fender well. I am looking for where did they get it. I did a google search and came up with a multitude of valves from $22 to $500, I am not sure what to use. Any suggestions? Anyone who has done this?
68Camaro68 is offline
post #2 of 9 (permalink) Old Feb 6th, 11, 08:40 AM
click's Avatar
Re: Installing a 12 volt solenoid valve
Jim what is the purpose for the valve? Are you trying to turn off water flow to the heater core?
click is offline
post #3 of 9 (permalink) Old Feb 6th, 11, 08:44 AM Thread Starter
68Camaro68's Avatar
Yes I am trying to cut off the water to the heater core....... Every year in the winter I install the heater hoses and in the summer remove them. By installing this valve that will eliminate my need to do this.
post #4 of 9 (permalink) Old Feb 6th, 11, 08:54 AM
Kip
I used a manual valve.(painted black). I installed it upside down which hid the mechanism. I routed the cable beneath the hose which effectively hid it.. Turned out very clean... almost invisible. Cheap too!!
kv67ssrs is offline
post #5 of 9 (permalink) Old Feb 6th, 11, 09:09 AM Thread Starter
68Camaro68's Avatar
Thanks for the reply kv67ssrs:
Does the manual valve provide better "shut off" then the factory valve installed in the car? Where did you get it?
post #6 of 9 (permalink) Old Feb 6th, 11, 11:40 AM
Kip
Got it at Napa... Worked great...
kv67ssrs is offline
post #7 of 9 (permalink) Old Feb 6th, 11, 05:52 PM
There is no factory valve, unless you have A/c and its vacuum operated.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #8 of 9 (permalink) Old Feb 7th, 11, 07:03 AM
click's Avatar
I had the factory type vacuum operated valve but it broke off its mount, so I replaced it with a brass shut off valve from local plumbing story, the 2 hose ends are ribbed and in summer I shut off flow so it doesnt get so hot in the interior, works great for me :
click is offline
post #9 of 9 (permalink) Old Feb 7th, 11, 09:55 AM
Michael
If you have factory AC, the vacuum controlled valves work great at improving the efficiency of the evaporator.
I needed a way to use the valve and provide a little height from the manifold to clear the alternator, so I used the 70's style vacuum valve on my '67. The engine is setup with the '69 style long water pump, pulleys and alternator while using a '67 intake.
I think they cost between $10-20.
mahunt is offline
